Old 07-24-2015, 09:25 AM   #1
fishlurcher
Drives: Toyota Yaris 2003 1.0 vvti
3rd 4th & 5th gear rattle
i have a 2001 Yaris 1.3 CDX 5 door all is fine except it rattles in 3rd 4th & 5th gears it's done 90k it stops when you cruise in 5th but is there under acceleration, I have done nothing yet not even checked gearbox oil, any ideas ?😕
fishlurcher is offline   Reply With Quote
Old 07-24-2015, 02:34 PM   #2
valchrist90731
Drives: 2007 toyota yaris sedan
Where is the noise and vibrations coming from?
Below you. Forward left or right center front?
Gear oil for manual transmissions supposedly has to be changed anywhere from 30 to 60,000 miles.
But i think it's not that.
Are you the first owner?
valchrist90731 is offline   Reply With Quote
Old 07-24-2015, 06:24 PM   #3
bronsin
bronsin's Avatar
Yeah first thing you do is get the gearbox warm (like before its winter) and drain that oil into a clean pan so you can examine it.
If you find a lot of metal in it (the oil has a metallic sheen) you've got a lunched tranny.
Or if no oil comes out, ditto...
If the oil looks OK put new oil in and see if you got the rattles.
Also, get the car up on ramps and go over the underside of the car looking for loose nuts and bolts. You just might find something...
Good luck and tell us what happens!
Old 07-30-2015, 09:40 AM   #4
fishlurcher
Thanks guys about to get to it been a bit busy, will first check oil level and condition, Not got good feeling but we will see 😕 let you know 👍
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 08:03 AM
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 09:16 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 09:16 PM
No 4th gear in A/T? caineroad General Yaris / Vitz Discussion 13 09-11-2009 07:47 PM
Yaris seems to get stuck in 3rd gear when going uphill 47_MasoN_47 General Yaris / Vitz Discussion 16 08-24-2009 01:22 PM
