Old 08-04-2015, 03:49 PM   #1
shepd
Drives: 2007 Yaris 5 door RS
Wheel bearing or ???
When I turn *slightly* left (even just enough left to correct for the crown in the road) I get a light rumbling feeling through the car and a noise like a worn bearing (whirrrrrrr). The harder the left turn, the stronger the feeling and noise. The pitch follows with speed, not RPM, and is present whether the clutch is engaged or disengaged. The noise seems to be coming from the front of the car.
Is the wheel bearing bad? I assume it would be the front right, as it occurs when turning left.
If it is, I notice RockAuto lists bearing and hubs as separate items. Does a typical replacement hub (probably going to be the Dorman part in Canada) include the bearing, or should I order that as well? I do have access to a press, though I'd have to put it back together so I'd rather just buy it all together.
Also, I notice they mention with/without ABS. Does that actually matter? Aren't the ABS rings pressed onto the axles?
shepd is offline   Reply With Quote
Wheel Bearing? devinlamothe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-12-2015 01:59 AM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 08:38 PM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 10:24 PM
Rear wheel bearing LeetViet DIY / Maintenance / Service 1 08-29-2012 08:41 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 07:34 PM
