![]() Drives: '08 Toyota Yaris Join Date: Aug 2015
Horn Problems
My horn is not working.. I have browsed endless pages on the Internet and found no solution.. It isn't the wheel because the relay makes a clicking noise, changed the fuse, tried a different horn. Now I'm stuck. Anybody have any suggestions? We did a motor swap on this when I bought it.. Not sure if it was working before or not but certainly isn't now ..
Thanks |
UPDATE
I put a test lamp on the plug that runs from car to the horn and connected it to my negative terminal on the battery. When I pressed the horn the test lamp lit. This means that it is not car-side that is messing up but horn side. What are the chances of going to pick a used horn off a damaged Yaris and getting another one that doesn't work? Is it possible the plug is making a bad connection? |
やりすぎだ~
Try connecting the + and - of the horn itself to the + and - of the battery. If it makes a sound, the horn is fine, too. Then it's the connection somewhere.
If you go to a salvage yard, you can pick a horn from almost any Toyota - it doesn't have to be a Yaris. Just bring your broken one and compare. |
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Nine,
Not to blow my own horn.....................................chortle, chortle, chortle. If it turns out to be the horn, I refer to my thread on my Fiamm El Grande install. If you're going to go to the trouble of replacing the horn spend $20 and get a horn, not a road runner impersonator, jmho. http://www.yarisworld.com/forums/showthread.php?t=51510. cheers. |
The small wire that goes from the harness to the horn is probably the issue. You can pop the plastic holders at the top of the bumper to give yourself enough play to get to it. On one of my Yaris, which had some front end damage before I acquired it, the wire looked to be intact, but it turned out that the wire was broken within the insulation.
| My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
| Problems after horn install | Astroman | DIY / Maintenance / Service | 14 | 04-07-2014 05:15 PM |
| follow up on 2010 yaris problems + more problems | heavenswaitin | DIY / Maintenance / Service | 18 | 09-03-2013 03:47 PM |
| Bungled horn install, eating fuses. | CrankyOldMan | DIY / Maintenance / Service | 12 | 05-04-2013 12:05 PM |
| Toyota Premium Horn | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 22 | 02-18-2009 11:28 PM |
