Old 10-04-2015, 12:51 AM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Rear mail oil seal replacement
First, please dont use my milage for referance. Because my car sees regular autocross action and track time, my 178,000miles is not the same as a daily driven only 178,000miles.
After autocross one weekend I noticed a drip of oil under my car, I jacked it up and saw this...
ArmstrongRacing is offline   Reply With Quote
Old 10-04-2015, 08:58 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
I don't recall where this is.
Mine had a leak around the timing chain cover. Redid the silicone seal, and replaced head gasket whole this was open.
Edit: here is my leak..
Sent from my A0001 using Tapatalk
Old 10-04-2015, 12:19 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
May want to check your PCV system before yanking the trans out. Pressure build up will usually push past the rear main, or front crank seals. Get rid of the pressure, and the leak may stop. Also, depending on how bagged your engine is, you may be getting too much blow-by for the stock PCV system to handle. May want to do a compression check. And finally, any oil leaks above the bellhousing tend to go in and drip out like that. Have a close look to make sure it's actually coming from inside the bellhousing.
Cheers.
Old 10-04-2015, 02:00 PM   #4
ArmstrongRacing
Data doesn't lie
I check my compression regularly, and I have a catch can. There are no other leaks and this leak gets worst when you drive the car vs idling, a indicator of a RMS leak.
Old 10-04-2015, 02:05 PM   #5
ArmstrongRacing
Data doesn't lie
Here is the old seal, you can see its not in goodshape, its also a bit hard where it should be flexible
Old 10-04-2015, 02:15 PM   #6
CoryM
OK. Looks like you got it well in hand. That seal is definitely not happy. I'm doing a clutch tomorrow on mine but I don't think the RMS will be needed. Same sort of life, but much less mileage.
Cheers.
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
