Drives: Too Many to List Join Date: Jan 2011
2ZR-FE Technical Question
I have a 2011 Yaris HB that I am starting a 2ZR-FE swap in. I understand all of the mechanical aspects of the swap. However, my hang up is with the ECU/Immobilizer. My Yaris is equipped with an immobilizer and the ECU that I got from a 2011 Corolla also is immobilized. My question is, can a Yaris VIN be written to a Corolla ECU with TechStream? Can the Yaris key be programmed to the Corolla ECU? If the Yaris VIN is written to the Corolla ECU, will TechStream detect that it is a Yaris VIN and attempt to flash the ECU with Yaris fuel/ignition maps? It seems that most vehicles that 2ZR-FE swaps come from are equipped with an immobilizer, so if someone could shed some light on this, or steer me in the correct direction to another option, I would be very appreciative. I really do not want to retain the factory ECU, even if it can be tuned via piggyback, for lack of dual VVTi control. Thanks in advance.
It is definitely more of a hassle with a 2009 or newer Yaris. You would need the ECM and keys from from the donor vehicle.
I would think not. immoblizer is usually a separate system. it will work or not. I don't think you'll have problems. I hope you have the vin for the corolla so you can get the brake code. otherwise you'll have to tow it to the dealership.
| License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 09:28 AM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 04:57 AM |
| Technical question about bigger injectors | LtNoogie | Forced Induction Forum | 1 | 08-14-2009 04:34 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 04:59 PM |
| Technical Question for the Suspension Gurus | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-22-2007 12:31 AM |
