Old 09-26-2015, 06:59 PM   #1
LeetViet
Drives: 07 Yaris 4DR
Headlight Lens Restoration
Tried the Turtle Wax Headlight Lens Restorer kit. Worked out okay for 15 minutes of work. It came with a "sealant" wipe, so we'll see how long the fix lasts.
LeetViet is offline   Reply With Quote
Old 09-26-2015, 09:35 PM   #2
I used that kit on my daughter's 2006 XB, when we purchased it last October. The headlights looked even worse than yours and they still look perfect, a year later.
Old 09-27-2015, 08:45 AM   #3
bairjo
Well that's good to here...ill try this on my sons Avalon. Got to be better than tooth paste,
bairjo is offline   Reply With Quote
Old 09-28-2015, 09:52 AM   #4
shepd
Drives: 2007 Yaris 5 door RS
Toothpaste works well. You just have to wet sand with various grits (From "coarse" (more like 500 grit) down to very fine (1000+ grit). After that, polish with toothpaste.
Once that's all done, rinse up the toothpaste, allow the headlight to dry. Apply several coats of clearcoat (krylon makes some nice stuff made for plastics). This method will last several years. I got 5 years of good headlights on my last vehicle, would have been more if it didn't go to the junkyard.
shepd is offline   Reply With Quote
Old 09-28-2015, 06:37 PM   #5
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
I wax my headlights every week after I wash my car.
Like posted above headlights are painted with a clearcoat from the factory and therefore need to be treated just like any other painted surface on your Yaris.
If you just remove the oxidized layer from the surface most likely it will return within a year if its an outdoor car and you dont continue to protect the lens from UV. Sometimes even worse since youve already removed some of the old clearcoat which has UV blockers mixed in.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 09-28-2015, 08:26 PM   #6
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
What do you wax it with? A special lens substance, or your regular paint wax?
Kalispel is offline   Reply With Quote
Old 09-28-2015, 10:58 PM   #7
soldout
soldout's Avatar
I dont use it if it dont say Mothers on the bottle.
No really any paste or liquid wax that your using for your paint can go on your headlights, taillights, windows, lisence plates, carbonfiber, wheels, anything painted or clearcoated should have wax on it as its first layer of defense against UV.
Old 09-29-2015, 02:27 AM   #8
bairjo
[quote=shepd;769935]Toothpaste works well. You just have to wet sand with various grits (From "coarse" (more like 500 grit) down to very fine (1000+ grit). After that, polish with toothpaste.
I'll keep that in mind....I just hope my dental hygienist doesn't by into this....thanks.
Old 09-29-2015, 03:47 AM   #9
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
It looks alot better than what you started with for sure. I used the 3M headlight restoration kit that I got from Amazon for around $10 shipped on sale and it worked great. Basically sanded down the lens with a low grit, then moved to a much finer grit sand paper. Then just polished it up with rubbing compound and a wax sealant that was provided.
07liftback is offline   Reply With Quote
Old 10-06-2015, 12:35 AM   #10
SirDigby
Drives: 2007 yaris 3 door
BG makes a great kit. it's expensive at $65, but it has 3 different gritts of sandpaper, a plastic prep, and a UV protectant that you apply and seal with a heat gun. works great. 3M makes a good kit too, but the UV protectant isn't great, and it wears after about a year/18 mo.
Old 10-18-2015, 06:30 PM   #11
indepth2
Drives: 92 volvo
Oxidation is not a big problem. As long as you don't remove the UV protection with sandpaper or abrasive polish you can keep the lens clear. Oxidation comes off instantly without damaging the UV layer by using a non abrasive liquid deoxidizer for acrylic lens.
indepth2 is offline   Reply With Quote
Headlight restoration Atlanta DataGoddess Southeast 9 03-01-2018 04:28 PM
Headlight Lens Showing Age IGGGY DIY / Maintenance / Service 18 04-19-2013 09:57 AM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 01:51 AM
Headlight Restoration Emerge Wash, Wax, Detailing, Exterior Repairs 23 06-26-2010 01:11 AM
