![]() Drives: Yaris I Join Date: May 2018
Headlight not working / Flash light works !!!
Hei ,
I had a problem in headlight. Flash lights working but normal light is very dimmed ( like not working ). Any idea , what's wrong. Im having TOYOTA Yaris I Hatchback (XP10) 1.0 16V (50 KW / 68 HV Thanks in advance. |
Check the headlight fuse. It may be partially burned out. It happened to me once. Replace it regardless.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Order bulbs from rockauto! 2$ each
Check wiring with multimeter after bulbs are tested |
![]() ![]() Drives: . Join Date: Mar 2019
If you replace the fuse and it immediately burns out, you may want to replace the headlight stem.
I had the same problem. When the stem (wand) switch wares out, it's short and blow the fuse. I was isolated and at night time so I used a 20A fuse to get me home for repairs. (NOTE: Using a higher amp fuse is dangerous and should only be use in extreme circumstances) |
| Remote start stopped working after installing LED brake light bulbs | xdeslitx | DIY / Maintenance / Service | 0 | 04-02-2019 01:12 AM |
| Yaris High Beam Issue Only one headlight is working | mik23 | DIY / Maintenance / Service | 10 | 12-30-2018 06:53 PM |
| P/S, Airbag lights on, Radio,fan,brakes light stopped working. | sarabjeet19 | DIY / Maintenance / Service | 4 | 01-31-2016 11:00 PM |
| SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! | tylerwatts53 | DIY / Maintenance / Service | 1 | 07-17-2014 08:53 AM |
