![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Yaris dead.
Ran fine this morning.Battery is tip top but nothing happens when I turn key.No noises or clicks period.Only thing that comes on is dash lights,oil symbol etc.
Bad starter perhaps? KSIbucky fixed it with 2 new fuses but he does not mention which 2 fuses https://www.yarisworld.com/forums/sh...501#post829501 I tried boosting and nada.So battery is fine. Bridged the clutch safety switch and no go. Anyone have any ideas on what fuses KSIbucky was referring to? Everything else works,wipers,mirrors,domes,radio,indicators,headli ghts,rear wiper/washer etc. Last edited by Pinchlite; 04-06-2020 at 05:46 PM. |
#2 | |
2ZR swap. DO IT! Ask how!
Check for loose battery terminals and blown fusible links under the red plastic cap on the battery. I was replacing an alternator once and shorted the positive terminal to ground with my wrench. No start, no clicks, nothing after that.
Last edited by CrankyOldMan; 04-07-2020 at 08:44 PM. Reason: added pic of fusible link block |
+1
#6 | |
Kinda glad I brought it to a shop because I did not notice the bearing was worn. So know just waiting for something else to go. Know to fix the low idle,almost stalling. |
Low idle is due to extended battery disconnect. The ECU now has to relearn your fuel trims. It will settle back in shortly. If possible, go for an uninterrupted 30 minute drive.
Glad to hear you got it fixed.
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Nice! Hopefully you won't have any more issues. The only major issues I've had with my yaris have been water pump, rear wheel bearings, and alternator.
To get 180k miles out of a car with only those minor issues is pretty good in my book, though.
I'm a hermit named Lee |
| FS: Various Parts from a 2009 Yaris Hatchback | Freestylin | Items for Sale by private party | 17 | 02-24-2016 10:36 PM |
| What is it about the Yaris | Ranger SVO | General Yaris / Vitz Discussion | 18 | 01-06-2015 10:45 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 12:03 PM |
| Dead Yaris... (or at least severely injured..) | 33OH | Photo-Video-Media Gallery | 45 | 11-15-2008 12:44 AM |
