![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
Clutch survey
I wanted to gather some information on here about our clutches. Let's list...
Year: Miles: Original clutch? If no, how many miles when you replaced it? I bought my car used with 72,000mi and am worried about having to replace the clutch in the next few years. The horrible throttle often makes me accidentally give the car close to 3000rpm when starting from a complete stop. No idea how the previous owner drove the car. If I took my car to a transmission shop, could they tell me how my clutch is doing or how much life may be left? |
My car years and mileage are in my signature details (show up on each of my posts). Original clutch in both of them.
Park your Yaris in a flat, open space (an uncrowded parking lot), and you can DIY. Do the Standard Clutch Test posted by Yarisworld member djct watt. See post #12 on the link below for this Standard Clutch Test post: http://www.yarisworld.com/forums/sho...ght=45k+clutch |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
2011 3-door.
Purchased November 1, 2010. 143,000 miles. Original clutch. But I think it is going to need replacement soon. I have the following symptoms: 1. On cold mornings, during the first couple miles, my clutch chatters or shudders when taking off from a stop. It did not do this when new and only started recently. But chattering could be a symptom of other problems such as burnt/glazed disk or a heat-checked flywheel. 2. The clutch seems to be engaging much closer to the floor than when I first bought it. But it has not started slipping, either during normal driving or when I test it. My test is a little different than the one posted above: Find a clear stretch of road. Start off driving normally and at about 20MPH, instead of shifting into 2nd, shift into 4th. Briefly punch the throttle about 30-40% then let go. If your engine revs up but the car does not accelerate accordingly, you need a new clutch. If your engine starts lugging or bogging, the clutch is okay. It is basically the same principle as the test as posted above but in a higher part of the power band. I perform this little test every few months on all my cars after they've accumulated a lot of miles. |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
155k miles. 07 Sedan.
Clutch chatters on cold starts in 1st. Doesn't slip at all. Gonna milk it as long as possible. Sent from my iPhone using Tapatalk |
08 Sedan
200K kilometers. just replaced clutch as it was juddering/shuddering on take off, i figured at 200K its probably gonna let go sooner than later, i'd rather have my mechanic fix it than some one i dont know while i'm driving half way across the country.
Have Yaris will travel.. |
![]() ![]() Drives: NCP91 Join Date: Jul 2012
108'000 km on factory clutch assembly.
Driven very hard and raced often. Frequent 4'000 rpm clutch dump launches. Double-clutched rev-matched downshifts every time, every day since purchase. Change your engine mount. |
2008 Sedan. ~185,000 Kilometers. Plenty of aftermarket power adders.
Blitz since about 60,000 Km. Original clutch. Occasional shudder during cold first gear take-offs. Bite is good. Disengagement however seems a bit deeper in the pedal throw than originally. May need a hydraulic fluid bleed???
do you do this because Fast&Furious told you to? why would you do this?? all this will do is make your master cylinder wear out twice as fast! do you have a straight cut gears in your trans? are you missing synchro rings? why would you double clutch???
#9 | |
Synchros or not, double clutching makes for smoother downshifting under certain conditions if done correctly. |
#10 | |
In doing this, pushing the shift lever into the gates during a downshift requires, literally, almost no effort, with only a cunt hair of resistance from the shift rod detents. Mind you, my Yaris gearbox still sees significant and frequent abuse. My upshifts are still normal "granny shifting" and is the only time my synchronisers are being used. |
![]() ![]() ![]() Drives: '09 Yaris 3dr, 13 F150rcsb 5.0 Join Date: Oct 2008
134,000 miles.
Original. As new.
You are what you drive. |
2ZR swap. DO IT! Ask how!
2009
Just died under 100k (changed clusters, can't recall the difference) Replacing with a Clutch Masters FX300 series. I don't do a very good job of rev matching when downshifting into corners, so I've dramatically shortened the life of the OEM unit. Started slipping about 3 weeks ago, completely shit the bed on the way to work this morning. Would have replaced it when I swapped gearboxes last summer, but didn't have the funds. Now I still don't have the funds, but have to get to work. The MR2 isn't really a commuter vehicle and needs LOTS of engine work to be reliable. |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Year: 2007
Miles: 81,000 Original clutch? No. Clutch replaced at 23,000 miles with TRD unit; was covered under warranty and I paid the $40 (yes, $40) upcharge to go from stock to TRD. Still has some clutch shudder in first gear.
Subcompact Culture: The Small car blog |
2007, bought of october 2006.
156000km Studders when cold, 1st and 2nd. Original clutch Sent from my A0001 using Tapatalk |
When you guys mention studder or chatter, when should I feel this? When pressing in the clutch pedal or releasing it?
![]() ![]() Drives: 2010 3dr yaris Join Date: Jan 2013
Releasing it, I have about 45000 miles and it has been doing that the last 10000 miles or so on the second take off in the morning. I am not concerned though.
Update: Driven about 40 miles on the stage 3 clutch. Wow. I didn't realize how much power I was losing to clutch slip until this bad Larry went on. Hooks up almost immediately, puts ALL the power down. Even makes the tires hop on bumpy roads when accelerating. I would describe the pedal feel as firmer than stock, but not uncomfortably so. I wouldn't want anything heavier for stop and go traffic, but this should do just fine for AutoX and spirited driving.
143,500km original clutch, bought car used w/ 87,000km on it so no idea how the clutch was treated prior.
The clutch shudders when cold in first gear, but no slip yet. I'll be bleeding the clutch within the next few months. I'm teaching my fiancee how to driive stick this upcoming summer so i'll be buying a good aftermarket clutch to install once she learns to install at the end of next summer. I can't stand the feel of the stock clutch.
| Getting Rid of the infamous Clutch "Shudder" | tmontague | DIY / Maintenance / Service | 14 | 07-08-2023 01:56 PM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
