![]() Drives: 2007 yaris Join Date: Mar 2012
alternator will not charge
The alternator in my 07 Yaris is not charging the battery . When the car is running I only getting 11.5 volts on my mulitmeter . I have check all the fuses in the charging system and all 4 are good. I installed a new alternator same problem . I also rechecked all the fuses after I installed the new alternator there all good. Any suggestions on what the problem might be
#2 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Check the large fusible links on the positive battery terminal.
CT how does one check these fusible links? Can one do visual? OR does one use an ohm meter?
#5 | |
For the alternator one, measuring the voltage on the large wire that connects to the alternator (with the grey plastic cover over the nut). With the engine off you should see battery voltage on that wire. If you do not, then the fusible link between the battery and alternator is blown and the alternator's output will not feed to the battery with the engine running.
ok I checked for battery voltage on the large wire that connects to the alternator (with the grey plastic cover on it) and I getting battery voltage. I also have checked all the fuses in the charging circuit ( 2 under the dash , fusible link, and the one under the hood in the fuse box) all good . I also installed a new alternator . My next step is to take my alternators to have them both checked. Could it be faulty computer system?
#7 | |
Also, with that in mind, check the 7.5A ALT-S fuse in the under-hood fuse panel and also the GAUGE and MET fuses in the under-dash fuse panel, as they are all involved in the voltage regulation process.
ok had the alternator tested , it was good , the gray plug is plugged in. I not sure what to do next . what else could be wrong , so far it not the fuses or the alternator , and the there are no codes are showing up besides the speed sensor which I think is do to the low power.
the car only has 74k on it
#10 | |
yes all 4 fuses 10a gauge,7.5a met,7.5a alt-s ,120 alt
OK. I would verify the following:
On the small grey connector check the voltage on the white wire with the ignition off. Check the voltage on the blue and green wires with the ignition on.
On the small grey connector checked the voltage on the white wire with the ignition off. 12.9 vots
Checked the voltage on the blue and green wires with the ignition on blue 10.8 v , green 4.6 v with engine running blue 9.83 v, green .36 v |
Humor me and try replacing the 10A GAUGE fuse in the fuse panel that is under the bottom of the dash.
ok I replaced the 10A GAUGE fuse in the fuse panel that is under the bottom of the dash. and the alternator worked. however the power steering, power windows speedometer ,airbag light were all intermittent , after a few days the alternator stopped working as well as all other electrical equipment. I at a loss I going to take it to the dealer to have them work on it unless some one has any other ideas
#16 | |
| Battery charge light on intemittant | vinny121 | DIY / Maintenance / Service | 18 | 08-24-2015 01:20 PM |
| How to rig up cell phone charge when car is off? | BennyLava | DIY / Maintenance / Service | 13 | 04-30-2012 10:40 AM |
| Battery: charge or buy new? | ziggyboy | DIY / Maintenance / Service | 9 | 10-17-2011 01:31 AM |
| 2012 Ford Focus ELECTRIC | Kal-El | Off-topic / Other Cars / Everything else Discussions | 11 | 02-11-2011 12:34 PM |
| How to charge 1F capacitor? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 11-07-2008 05:20 PM |
