![]() Drives: Toyota yaris 2005 Join Date: Dec 2015
need help with the wheel rims (DIY)
Hi folks!
I wonder, is it real to repaint the rims, without removing the previous paint? The point is that I have wheel rims with scratched surface. Can I take any fast drying paint to upgrade them? Thanks for your opinion. |
![]() ![]() Drives: 2007 2DR Liftback Join Date: Oct 2011
I repainted my OEM steelies this past summer.
Took them off (left tires on the wheels) the Yaris, scrubbed them clean using Dawn and then a degreaser (Purple Power, etc.). Let dry, then scuffed the old paint with a red Scotch-Brite. Dusted, and final wiped with Windex; let dry. Masked off the tires with index cards (and a round piece of cardboard and duct tape on the back side to prevent overspray on that other side of the tire; also the valve stem). Then two or three heavy coats of high temperature gloss black Rustoleum spray. Let dry, did other sides, let dry overnight, then reinstalled. Let dry for a week before reinstalling the wheelcovers. Look great now! The Yaris looked mean without the wheelcovers; I was tempted to leave them off. |
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
You can also try plasti dip. If after a while, you don't like the colour, you can just peel it off and go back to the original colour. It does not harm the original paint.
![]() Drives: 2012 Yaris Join Date: Oct 2015
If the paint is solid, no rust, etc yes you can just scuff and paint. If the paint is bad your best bet is to sandblast them down to bare metal, prime then repaint.
Good luck |
#5 | |
thanks guys, you gave me good tips
#6 | |
Degrease the wheels using dishsoap (or I rub them down with denatured alcohol). Scuff up the surface to allow the primer to bond. Either use sandpaper or coarse ScotchBrite pads. Use a good and compatible (with the paint) primer. For your Krylon paint, Krylon's primer works well.
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 05:20 PM |
| My 17" alloy rims and Kumho tires... will swap for your original wheels! | AutoWashCars | NY / NJ/ CT / PA | 5 | 02-08-2011 08:38 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 03:37 PM |
| DIY : Tutorial : Paint your rims....! | hasher22 | DIY / Maintenance / Service | 17 | 11-06-2006 07:54 PM |
