![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Hi All, my 07 sedan has about 92k miles and it has always been spraying coolant on the underside of the hood (left side) since 3 or 4 years ago.
should I take it to a dealer to replace the water pump & serp belt to ensure it is done right? or take it to a private shop for a cheaper price? |
If you know a reputable private shop I would go there.
As a mechanic, I always suggest to go to who you are most comfortable with to do the job correctly, and not oversell things. Whether it is a private shop or a dealer, some are good some are bad. The dealer does not guarantee the job will be done correctly though. For example just today I had a customer come back because we recommended he replace bushings on his truck (they were obviously torn, in an important area). He took it to the dealer because he had some warranty work to be done, and they said there was nothing worng with the bushings. Almost 1/2 of it had torn off the metal..... So today I showed him the obvious tearing and explained why it's a problem.
Waterpump is a pretty easy thing on a Yaris. Pretty well any shop should be able to do it for you. The only thing I would suggest is ask for Toyota coolant if you take it to a private shop. Waterpump can be aftermarket, but go for Toyota coolant. Cheers. |
| Fuel filter replacement | jaimico | DIY / Maintenance / Service | 43 | 03-07-2023 12:05 PM |
| water pump change 2sz-fe | finnpoulsen | DIY / Maintenance / Service | 5 | 03-25-2020 11:20 AM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 11:41 AM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 09:59 PM |
