Old 07-16-2013, 11:32 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Finally, my motor went.
I must say, I pushed it for a long time... so this was bound to happen. I was simply driving home a few nights ago and did a full boost (30psi) pull, right at redline in 2nd gear I got valve float. I have had the rev limiter set at 7500 for about 5 months, but it was pure luck I made it that long on a stock head. I was barely able to make it home, the car barely ran.
Im hoping the bottom end is ok, and just some minor damage done to piston tops.
Garm, I noticed you carry upgraded valve springs, Ill be contacting you soon about those and a intake manifold. Also cam options, if there are any.
I was able to squeeze 60k miles out of this motor without any snags until now!
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-16-2013, 11:40 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The BC Valves come highly regarded. There is also the JUN Cam pair designed specifically for turbo applications.
Old 07-17-2013, 12:52 AM   #3
You did great, made us all proud with your build. We can grind cams for half what JUN charges, I would never pay their prices.
Old 07-17-2013, 02:47 PM   #4
kou
Drives: 08 lb
You had great numbers before and beat it up for a long time so I cant wait for your next build.
Old 07-17-2013, 08:39 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
*Engine :P
but besides that, it is time to go crazy, you know grind some cams, up grade the valves, port and polish, all that stuff that makes more ponies
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 07-17-2013, 09:38 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Regrind cams sounds fine to me. Ill do those, springs, and possible port and polish. I am interested in the golden eagle manifold, what tb flange options are there?
Ptuning.com
Old 07-17-2013, 10:34 PM   #7
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Do you have a link to your build thread? I don't want to ask a bunch of questions that you have already posted answers to.
Did you do a teardown already? Interested to see what the motor internals look like.
The Spectacle is offline   Reply With Quote
Old 07-18-2013, 09:40 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I don't see an actual full thread build. But if you look up his name and all the threads Blown xA started, you will find alot of the answers you seek.
http://yarisworld.com/forums/search....archid=1580961
-Derrick-
Old 07-18-2013, 07:21 PM   #9
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I never made a build tread, Im weird lol
Ptuning.com
Old 07-18-2013, 07:30 PM   #10
Whatever you want, it comes 1ZZ/1NZ, but we've made 1NZ cable (xA/xB) and larger (70mm) flanges as well. All available.
Old 07-18-2013, 07:31 PM   #11
Do I smell 10's on the horizon?
Old 07-18-2013, 11:19 PM   #12
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
that is the plan yep. I need another 50-70hp, that should get me there if not very close .
Ptuning.com
Old 07-19-2013, 02:34 PM   #13
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Hey when you ran that 12.9 in your sig, what was your whp?
Yoda is offline   Reply With Quote
Old 07-19-2013, 04:34 PM   #14
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
good news for this little guys!
Old 07-19-2013, 06:29 PM   #15
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
286whp at that time, with oem steelies. The 11.9 was with slicks and 318whp. I am currently at 352whp but haven't run it yet ( not that I could now anyays )
Ptuning.com
Old 07-20-2013, 01:33 AM   #16
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Have you popped the top see what failed yet?
Old 07-20-2013, 08:55 AM   #17
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Ill probably do so next month, have a bore scope at the shop too. Right now, my focus is elsewhere (downhill/streetluge racing).
Ptuning.com
Old 07-21-2013, 01:32 AM   #18
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
I sad to hear about your motor but i think the motor has had a good life. good luck on your next build.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Finally!!! SkittlePig Australia 11 07-05-2010 08:49 PM
FINALLY!! nickhjort DIY / Maintenance / Service 18 01-17-2009 12:09 AM
Yay finally got my YRX (photos) Spikeles Australia 15 11-12-2008 04:16 AM
I'm FINALLY getting my Yaris! sherryberry New YARIS Purchase Forum 22 07-09-2007 01:08 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 10:16 PM
