wider Tires
I have 2015 Yaris 3 doors with following tire size P175/65R15. I would like to have wider tires installed, can I go with 195/65R/15 or what other size,thanks for any information.
195/60/15's fit nicely on stock wheels and suspension.
Keep in mind that the /65 in the tire size is the sidewall height as a ratio to the tire width. Increase the width of the tire and you need to downsize the sidewall ratio. A 195/65R15 will therefor be a taller tire than the 175/65R15 and would throw off the accuracy both your speedometer and odometer.
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
mine came as 185/65/15 stock...going for 195/50/15 a little bit wider but reduced side walls..
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
195/55-15 are very close to stock size. A bit shorter but as close as you can get to
my originals which were 185/60-15. I also had 175/65/14 steeles with winter boots and a set of 215/35-18 on TRD wheels (pictured to the left).
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Here is a link to my favorite tire size calculator. It compares the original size to a selected new size and gives you the differences, and how it will affect the speedo. I use it all the time at work.
Tire Size Calc |
![]() ![]() ![]() ![]() Drives: street-legal go-kart Join Date: Oct 2008
i have 195/60/15 on my 07 and it works well. something you might want to think about is the price as different sizes i noticed while shopping for new tires can be more expensive than others(ie the 195/55 was more than either 195/60 or 195/50).
#9 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
)in any case, they are right, the right upgrade for wider tires would then 195/55 r15. but 195/60 r15 is not bad, but is a larger tire, and ideally good for your highway mileage, but bad for your stop-and-go city mileage due to rotational inertia. (your car will be higher, but the fender gap will also be less.) |
| Existing stock tires on a wider rim, any Fuel Efficiency cons? | hondaconvert | Fuel Economy Forum | 3 | 09-06-2012 01:47 AM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
