Old 04-16-2020, 07:04 PM   #1
gubloom
Drives: Silver yaris
Drivers Side Power Window Not Working
Hello,
I have a 2016 model Yaris with 65000 miles.
My drivers side power windows stopped working. All other windows work and I can control all windows from drivers side control buttons. All power doors work as well. I got a second hand drivers side control button but the problem is the same. Everything works but not drivers side power windows.
At this stage I believe its the motor.
My question is - is it possible its anything else ?
gubloom is offline   Reply With Quote
Old 04-16-2020, 11:43 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The driver's window motor is powered through a separate fuse to the other windows. Assuming the wiring hasn't changed from my 2012 Yaris, check fuse number 14 (Door, 20A) in the under dash fuse panel.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 04-17-2020, 01:00 AM   #3
gubloom
Thats useful do you know if that fuse is for the door as well because the door opens using remote key
Old 04-17-2020, 07:37 AM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The power door locks are separate to the power window circuit.
There is a separate 20 Amp fuse for the window in eadh door, as well as a common 30 Amp fuse for the window control system. The individual fuses for the windows are labelled "Door", "Door P", "Door R/R" and "Door R/L". These are for windows in the driver's door, front passenger door, rear right door and rear left door respectively.
The driver's window motor is different to the other three as it ties into the body control module for the auto open/close function. If you have to replace the driver's window motor, there is an initialisation procedure for the new motor to synchronise the motor and Body Control Module for the auto open/close function so that the motor stops when the window is fully open or closed.
Old 11-26-2024, 06:38 PM   #5
JustFPV
Drives: 2006 Yaris 2dr hb manual
Just putting this here in case anyone else has this issue, check the button on the drivers side window/lock panel that disables the passenger windows function. I recently swapped my interior from base to rs. I own an 06 base manual hatch and harvested the interior seats, trim, door panels and bumpers/skirts/spoiler from 08 rs hatch model. After doing the cruise control upgrade and swapping the interior, I couldn't open my passenger window. It ended up being the button was turned on to disable to passenger window control on the rs panel and it's a common thing that happens accidentally with our cars. Try pressing the window lock button before you start pulling the door apart or hunting through fuses and wiring.
JustFPV is offline   Reply With Quote
Power window mamun22s DIY / Maintenance / Service 1 08-30-2012 08:35 AM
Power window motor BMGYaris DIY / Maintenance / Service 10 01-22-2010 10:09 PM
