Old 04-25-2016, 07:04 AM   #1
CB900F2
Drives: 08 Sedan
U340e Fluid Capacity w/Strainer(filter) change
Hey guy..
Wondering if anyone knows how much transmission fluid would be needed if one was to perform a drain and refill on the U340e, but also replacing the fluid strainer(filter).
I have read that a drain and refill only is 2.9L, and full capacity is 6.4L..
Thanks all
Old 04-25-2016, 07:34 AM   #2
Correct - Without completely disassembling the tranny and dumping out the torque converter 3L is the max you will extract, even with pulling off the strainer.
Old 04-25-2016, 07:45 PM   #3
CB900F2
Drives: 08 Sedan
Thanks Scott
Also.. Do we check the fluid level (hot or cold) with the car running, or not running?. I read again a few places where for the yaris, some say check it in park and the car running, and other say in park and not running..
Thanks!
Old 04-27-2016, 07:13 AM   #4
CB900F2
Drives: 08 Sedan
Anyone??
Originally Posted by CB900F2 View Post
Thanks Scott
Thanks!
Old 05-15-2016, 09:25 AM   #5
CB900F2
Drives: 08 Sedan
For all.. In my case... when I drained the fluid, and then pulled off the strainer and that additional fluid came out.. It took approx. 3.8 liters of fluid to bring the level back to the point where it was in between the HOT marks when I would drive the car for about 30 min and checked the level when the car was in park and idling..
regards
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 11:42 AM
Automatic Trans fluid change interval? charles nelson DIY / Maintenance / Service 2 02-08-2013 08:25 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-27-2012 12:48 AM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-11-2011 12:51 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
