Old 04-27-2016, 09:40 AM   #1
Carquestions
Drives: 07 Yaris
Belt Squeal mystery solved
I did some testing on a Yaris I've been working on for a while and may have come up with a solution for the belt squeal - If you have replaced or tightened your belt and are sure there are no bad pulleys etc and you still have the squeal try the "turn key slowly" trick like in this you tube video - https://youtu.be/HRrVMtyIqIY
Carquestions is offline   Reply With Quote
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 07:19 PM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 11:41 AM
Drive belt squeal at idle. junorico24 DIY / Maintenance / Service 22 03-29-2013 10:27 PM
MPG Mystery SOLVED! otterhere Fuel Economy Forum 64 12-13-2008 09:43 AM
