Old 05-08-2016, 04:37 PM   #1
Midwesterner
Drives: 2009 Yaris Hatchback
Busted Radiator
I hit a raccoon early this morning on the highway. The temp. lights and check engine lights were on shortly after I hit it and I took it the last few miles home.
I took a look - the radiator was pushed back into the engine, which poked a hole in it. The question is whether I should have it towed or if I can make it 2-3 miles at low speeds (20-25 mph) to a repair shop. Of course I know there is a risk here, but trying to weigh the risk with the cost.
I attached a photo of the hole. There is some small amount of coolant below the hole, but it is very low. To avoid more spilling, I did put a pieced of duct tape over the hole, but obviously that only minimizes loss of coolant and doesn't stop it altogether.
File Type: jpg 13102668_10153971841085546_2452213028365073857_n.jpg (11.7 KB, 64 views)
Midwesterner is offline   Reply With Quote
Old 05-08-2016, 06:08 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I know this doesn't pertain to your immediate issue, but I have my OEM radiator and fan/overflow unit if you want it.
Sent from m-o-b-i-l-e
Old 05-08-2016, 08:22 PM   #3
bronsin
bronsin's Avatar
Is there coolant in the radiator when u remove the cap?
Old 05-08-2016, 08:30 PM   #4
Midwesterner
Busted Radiator
Yes, but the level is really low. AS you can see from the pic, the hole is not all the way in the bottom. There is some coolant well below where the hole is.
Old 05-08-2016, 08:44 PM   #5
That is not the radiator - it is the overflow tank, which mounts to the radiator, but is only connected by the little hose from the radiator fill neck. The radiator cap is on the upper hose. Remove that (not hot) and check to see if you have coolant in the system.
Old 05-08-2016, 08:56 PM   #6
Midwesterner
That makes sense, sorry. I used a flashlight to look down into the big hose under the cap, and it looks like it is a bit damp is all.
Sent from my SM-N900R4 using Tapatalk
Old 05-08-2016, 09:11 PM   #7
Midwesterner
1.6 Miles
I mapped it, and it is 1.6 miles to the repair shop. I'm thinking maybe I should go tonight after dark and it cools down, then drop it off and call them tomorrow.
Old 05-08-2016, 09:46 PM   #8
Fill it via the cap with water and look to see if the radiator is actually dripping. From there you can tell if the run is safe or not. If it is slowly dripping you should be fine, but if it quickly loses it, it is more risky, but keeping it slow should prevent it from getting hot in that short of a distance.
Old 05-08-2016, 09:47 PM   #9
Midwesterner
Thank you.
Old 05-08-2016, 10:30 PM   #10
Midwesterner
It's gushing
The water is coming back out pretty fast.
It doesn't matter anyway because it won't start anyway. I wonder if I also damaged the starter. :(
Old 05-08-2016, 11:47 PM   #11
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Bet that raccoon won't start either
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 05-09-2016, 05:08 AM   #12
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
what about the racoon..is he any good?
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 05-09-2016, 08:28 AM   #13
bronsin
bronsin's Avatar
You have to take the cap off the radiator not the white plastic thing.
Does the starter crank the engine?
Old 05-09-2016, 08:36 AM   #14
Midwesterner
Yea, I put water under the cap with a warning about not opening hot, which is over the big hose.
There is no cranking at all.
Old 05-09-2016, 09:29 AM   #15
Midwesterner
It might be as simple as something disconnected, though. In any case, I am just going to get it towed today.
Old 05-09-2016, 11:43 AM   #16
bronsin
bronsin's Avatar
Good luck and tell us what happens!
Old 05-09-2016, 12:02 PM   #17
Midwesterner
Thank you all for your help - I'll let you know what happens. It is a local small mechanic shop, and I told the guy I don't care about anything cosmetic. I just need it to reliably run.
I asked him to not fix anything until talking to me... it has nearly 160k miles, so if it too much cost, I might just replace it. I also need to get new tires in the next couple weeks, so could probably end up with $1K or more this month.
Old 05-09-2016, 12:13 PM   #18
bronsin
bronsin's Avatar
For $1000 I'd keep it!
Tags
radiator
Radiator Fan not working.. Beubeu DIY / Maintenance / Service 3 09-21-2015 01:53 PM
2007 Yaris Radiator Fan kcanaj Yaris TS Talk 1 07-25-2015 10:13 PM
radiator small leak esse10 DIY / Maintenance / Service 2 08-20-2013 12:40 PM
Radiator Change TMR3 DIY / Maintenance / Service 5 06-22-2012 01:11 PM
Radiator hose size window_lee General Yaris / Vitz Discussion 0 03-31-2009 07:33 AM
