Old 05-24-2016, 04:30 AM   #1
Nahid
Drives: Toyota Vitz
Need help on engine coolant check
I am not a car expert so pardon my novice question. I want to properly check engine coolant (locally called radiator water here in Bangladesh). A local mechanic is telling me that my car needs to be added engine coolant. I have checked the user manual and it suggests that I need to check engine coolant reservoir to check if it needs more fluid. On the whitish reservoir box the pink fluid is above 'full' mark but if I open the radiator cap than the pink fluid is not visible. Should I top up engine coolant?
Nahid is offline   Reply With Quote
Old 05-24-2016, 06:48 AM   #2
The fluid will never be up to the cap when cold, but should be visible in the neck when you open the cap.
Old 05-24-2016, 01:33 PM   #3
Lafiro
Drives: 06 Yaris Sedan
I thought mine was leaking because it was below the low mark when checked end of last year. I purchased antifreeze from Toyota and I filled it. Now its above the full line.
Would that cause any issues?
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
check engine code P0101 bugg_master Performance Modifications 6 09-24-2016 02:41 PM
2SZ-FE custom air intake check engine light JDM::RSTLESS DIY / Maintenance / Service 8 08-17-2014 12:42 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 06:10 PM
