Old 06-04-2016, 12:47 PM   #1
Tinkerman
Drives: Yaris 5 speed
Low Idle fixed!
Well, I just bought the Yaris with 65K miles. Once the car is at operating temp the idle seems to drop a little too low for my taste, the low idle caused some vibration what appears to be soft engine mounts, a low freq vibration enough to be annoyed.
So I changed out the plugs that didn't do it, but after cleaned the MAF and replaced the air filter, the low idle problem is now gone.
Using my phone Torque App I was able to see a 40 RPM increased at idle, the car idles nice and smooth now at 600 RPM.
Wish I had performed the above 2 tasks one at a time, but doesn't matter they both makes sense for the increase of RPM anyway.
Just wanted to put here for future purposes, and thank you for reading.
Cheers!!!!!!!!
Tinkerman is offline   Reply With Quote
Old 06-05-2016, 06:14 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
cool, i have that problem in another car (RAV4), especially with AC on. it's due for air filter change. will see if that helps.
jack black is offline   Reply With Quote
Old 06-05-2016, 06:18 PM   #3
Tinkerman
That's strange. Usually with A/C on the idle should raise. But, good luck.
Low idle speed after battery disconnected YarisTR-VVT DIY / Maintenance / Service 3 12-08-2015 08:20 PM
Fix For Low Idle When Warm On A Yaris Mk1 danielbb DIY / Maintenance / Service 0 06-12-2014 05:13 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 09:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 09:41 PM
