Old 02-04-2016, 03:20 PM   #1
ViosBelta
Drives: Vios 2009
RANDOM ELECTRONICS RESET
Hi all! I'm from the philippines and i own a 2009 vios which is the same as the yaris sedan. My car's electronics will randomly reset cluster light and gauges blinks then dies , radio shuts off, power steering doesnt work, headlight/fog light/indoor light flickers this happens in a couple of seconds the everything will work again with the exception of the power steering which needs another start up to make it work. This happens usually at night when i have the lights on. Battery is OK. Alternator is OK... The only thing i notice is i don't have passing lights(when my HL is off, i have Hi/Low Beam when it is ON) and my speedo doesnt go down to 0 it just stays at between 5-10kph when idle.
Scanner detected the codes:
C0200 :
front current speed sensor RH Circuit
C0205: Front current spped sensor LH Circuit
ABS/VSC NOT OK
MAIN BODY NOT OK
are any of these codes related to the issues i have? If not what could be the problem?
Thank you, YARIS WORLD.
ViosBelta is offline   Reply With Quote
Engine runs fine after ECU reset, poorly shorty after Zachccccc DIY / Maintenance / Service 30 01-21-2016 10:41 AM
Needs some help with a very random random misfire Echo02 DIY / Maintenance / Service 8 03-28-2013 11:28 PM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 11:03 AM
Reset ECU ? packetrace Cosmetic Modifications (Exterior/Interior) 6 09-01-2011 06:27 PM
