Old 06-26-2016, 12:52 AM   #1
froger
Drives: 08 yaris 1.8 dual vvti 5sp
2ZR-FE CARTRIDGE OIL FILTER TO METAL OIL FILTER
Recently I found that Toyota is going back to metal filters and so decided I would swap my 2zr-fe motor too.The swap to metal filter is very simple but the parts might set you back a little.I took my parts from a scion im because I wanted japan built parts but a 2016 corolla will work as well(USA part numbers
are different.)
Here are the japan part numbers used
1 X bracket, oil filter 15609-37010
2 X gasket,o-ring 96723-24020
1 X oil filter Union 90904-04006
1 X (japan)oil filter 90915-10004
REUSE 4 MOUNTING BOLTS
Basically you unbolt the 4 bolts holding the filter assembly and then change the
2 O-rings, after that just bolt the new filter assembly.
froger is offline   Reply With Quote
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Missing oil filter = engine locking Ball3rina DIY / Maintenance / Service 5 06-20-2012 01:30 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
