![]() Drives: 02 Yaris 1.5 T-sport Join Date: Dec 2012
Hi guys,
I installed an iduction kit to replace the standard air box today. It started fine, idle seemed ok, but when I took it for a test drive it was very slugish and sort of bogged down a low/med revs. Seemed to run a bit better with higher up the revs. I ended up putting it back to standard shortly after as I needed to use it and it ran fine so the maf must be ok. Any idea's why it ran like that? ![]() Thanks |
play every day
You could try putting your new intake back on and disconnecting your negative battery cable for about ten minutes so that your computer will forget the old stock air box operating parameters, and learn the new parameters of your intake.
What's the inside diamater of the pipe on the new intake? If it's any bigger than stock the MAF will read less air passing by and give less fuel making LESS power.
#4 | |
The ECU is very particular about air passing the MAF. Deviate from 2.25" inside diameter on the pipe and you'll typically run into problems.
#5 | |
yes but only for a couple min, will be tryng it tomorrow also |
#6 | |
Only a tad bigger, wouldn't Imagen that small a difference will cause a problem would it? |
#8 | |
So today I had another go at sorting it out. Reset the ecu as sujested. It did run better but still no where near right.
Ive put it back to standard untill I can remake it with a smaller ID tube or of course get a premade one. Does anybody know what size ID the aftermarket one is? |
Could be one or both of what was mentioned above.
Disconnect the negative terminal on the battery. Pump your brakes until it becomes stiff. Let it sit for like 10-15 minutes. Reconnect the battery terminal, and start your engine and let idle for ~15 minutes. Do NOT step on the gas or anything, just let it idle. That should help. |
Cool ill give it a go, what does pumping the brakes do?
Just a little extra to get any and all residual charge out. I've had better luck with pumping my brakes than not.
Did you disconnect the battery when installing, so your ECU can relearn with your new intake?
DAT'S RIGHT I GOTz 2
what brand intake did you get?
#18 | |
play every day
Weapon R 57mm Simota 59.5mm Both work fine, and the difference might be the wall thickness of the tubing. I'll need to disassemble them to get the more accurate inside measurements. How your MAF sensor is positioned relative to the center of the tubing is important. Maybe spacing it up or down will help. I'm taking the intakes apart today to get a better fit on the throttle body so I'll take some measurments and let you know. ![]() Greg |
| WTB Forced Induction kit | JohninVT | Willing to Buy by private party | 5 | 11-12-2012 03:24 PM |
| how to fit induction kit to my p1 | daveyboigt | Performance Modifications | 0 | 10-21-2012 05:06 PM |
| Induction air filter on yaris diesel - good or bad?!?! | Ziishan | DIY / Maintenance / Service | 3 | 10-20-2012 08:43 AM |
| VIS jdm rs body kit | Dperry | Cosmetic Modifications (Exterior/Interior) | 2 | 05-06-2012 11:00 PM |
| Greddy xB kit vs Greddy Fit kit | ellenbetty | Forced Induction Forum | 52 | 09-29-2009 08:42 PM |
