![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
steering Rack ends replacement how to
Has anybody done this before? According to the manual, the whole steering assembly needs to be removed. Is there a way to remove the rack ends without removing the whole steering assembly?
10 years... alive and kickin'!! ![]() ![]() |
I had to have mine replaced at 40k, I suspect due to a friend backing into my car while parked behind her. Toyota did it, as I was still under extended warranty, and from what I understand they had to damn near pull the whole dash out, including steering assembly. Not 100% sure, again, since I didn't do it myself.
#3 | |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Are you referring to inner tie rods?
No one ever wants to give a Yaris the point by... ![]() |
correct, inner tie rods.
All the tutorials or how to's i've found refer to a socket type tool, which I can only find online but is not available here. I would get it from ebay but I need to have my car ready before friday. Any workarounds are welcome ![]()
You do not need to drop the subframe or remove the steering rack from the car. Go to your local auto parts store and rent the tool if you have that available to you. If not then order it online. The car should be fine to be driven until it comes in the mail.
I just rented the part for free from my local parts Source. It was very simple to do, I just turned the steering wheel all of the way to the opposite side I was working on which made it even more accessable. I used a zip tie to keep secure the boot back onto the inner tie rod. Here is a video outlining the job really well. It's all I used to replace the one on my Echo https://youtu.be/05XOhz67jGA On some cars you can get a wrench around the inner tie rod and you can avoid buying the tool. I inspected my Echo to see if that could have been done but to be honest I don't think it would be possible without the tool. Or if it is it would be a pita and take much longer then it needs to. It's not a bad job to do on your own and everything is pretty easily accessible.
After calling several auto parts store, nobody rents them, so I had to buy it. 45$, not that bad, considering that I can re sell it/rent it or doing it to other cars and earn some cash from it.
I was trying to get the pipe-like tool but this is the only one I found: ![]() ![]() I'm doing a long trip this weekend, therefore I need to have it done ASAP. I also need to replace the dryer filter and the expansion valve from the AC. Hopefully I'll do that tomorrow after the alignment.
Hmm, never seen a tool like that one. Let me know how you find it works. $45 is a good price compared to the others that run over $100
Ok, so the tool should work fine, however, it comes in two sizes. I got the bigger one which does not fit the rack end. I'm going back to the store tomorrow to get the right one.
I got the replacement tool and was able to do the job. The new inner tie rods came with a washer but the original one did not. In fact, the manual does not even mention it. I tightened it pretty hard so I don't think that could be an issue.
Fwiw I never used the washers either when I replaced my inner tie rods on my Echo
#13 | |
Anyhow, as I said, alignment was done, car is back in track now!! I am ready for the trip
Drives: 2009 Yaris Join Date: Dec 2018
how difficult is it to replace a 2009 Yaris Rack? Working on it...
320K miles so far. going strong! |
Thread Tools | |
Display Modes | |
Inner tie rod replacement - rack assembly? | jwpaine | DIY / Maintenance / Service | 1 | 02-04-2015 07:22 PM |
Replacement Radio + Steering Wheel Control Questions | dinop | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 07-07-2013 01:31 PM |
OEM roof rack mounting rubber pad replacement | Yai | Cosmetic Modifications (Exterior/Interior) | 3 | 12-22-2012 12:01 PM |
The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
Upgrade Steering rack bushings?? | aeipee13 | Performance Modifications | 1 | 07-14-2009 02:17 PM |
