![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
After reading as many threads as I can, I'm still unsure of how to diagnose a no cold air issue.
What I am seeing and experiencing; - no cold air at all, not even briefly - no typical drop in RPM when a/c engaged via climate control button - no bubbles visible in sight glass What I have done; - check all fuses and they are good - briefly depressed low pressure line valve and pressure was released - cleaned pressure switch connector When I depressed the line valve, bubbles did appear in the sight glass. These went away once engine was restarted. No subsequent bubbling appeared. It should be noted that I do not currently have access to pressure gauges or a multi-meter, so I cannot perform any diagnosis that involves those items. Finally, a rookie question. Visually, how can I tell if the compressor clutch is engaging since the pulley is always spinning? I'm guessing that if the disc located on the left side of the a/c pulley is spinning, then the clutch is engaged. If that is the case, then my clutch is always engaged. Thanks in advance for whatever insight can come my way.
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 10:17 PM |
| The open political discussion thread. Read the first post! | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 342 | 09-15-2009 01:34 AM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 01:11 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 09:53 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 06:37 PM |
