Old 10-14-2014, 12:40 PM   #1
Mika
Drives: Yaris 2007
Yaris Sedan 2007 - Idle RPMs too low
Hi guys!
Here is my query.
Situation: The idle RPMs are lower than usual. This happens even when I have the A / C on or off. If I'm moving, and suddenly brake, the RPMs drop drastically, and then go up a little, but still too low. This happens also with the lights on or off.
I cleaned the throttle body, and also the mass airflow sensor, but the condition persists. I also changed spark plugs, air filter, PCV and nothing.
* I noticed that the dash lights decrease, and that the A / C starts throwing warm air.
Please HELP ME !!
Mika is offline   Reply With Quote
Old 10-14-2014, 01:20 PM   #2
colj00
DIYer
Drives: yaris 1.5 MT
auto or manual?
colj00 is offline   Reply With Quote
Old 10-14-2014, 01:43 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
What is your RPM at idle?
Old 10-14-2014, 03:20 PM   #4
Mika
Drives: Yaris 2007
Originally Posted by colj00 View Post
auto or manual?
Automatic
Thanks for answering.
Old 10-14-2014, 03:24 PM   #5
Mika
Drives: Yaris 2007
I'm not sure. Let me find that information...
Old 10-14-2014, 09:43 PM   #6
beaker
Drives: 07 Yaris 3 door
I have an auto too, and mine does the same thing in stop and go traffic. Kinda stumbles a little then catches back up, but sometimes it seems to idle a little rough. In fact, mine threw a check engine light this morning. Code is a P0101, Mass Air Flow Sensor. I've got 161k on it, so I'm thinking I may need to replace the sensor. i wanna check it with a component tester first, to make sure, because the sensors is expensive. Probably could use a good fuel injection cleaning also.
beaker is offline   Reply With Quote
Old 10-14-2014, 11:43 PM   #7
jcboy
Drives: Sedan 07
Dont worry about your 2nd statement. These are expected when your idle is too low.
Re your concern, im out of ideas considering you have done the thinga i have in mind.
Old 10-14-2014, 11:59 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Look,, this is normal for the Yaris. The rpm's always seem too low, and drop like a rock. As long as you are not stalling, the car is ok.
Colin Chapman disciple
Old 10-15-2014, 06:28 PM   #9
Mika
Drives: Yaris 2007
Here is the RPM information that you ask me for... Usually 630-648 is the idle, and the other pictures are the drops without recovery.
Old 10-15-2014, 06:57 PM   #10
sheekeebut
Minimalist
Drives: 07 silver sedan
Looks about right to me. My 2007 Canadian sedan manual is just above 500. It dips below briefly when I make any accessory actions like turning AC/defroster/headlights/fan on OR off
sheekeebut is offline   Reply With Quote
Old 10-15-2014, 11:15 PM   #11
Mika
Drives: Yaris 2007
Mine, is a/t...
Is just that, it wasn't like that before, and now I'm having an A/C issue while idling, for example. I can live with a soft shaking thing, but no with warm air while idling. Something has changed. I just need to figure out what.
Where can I find official information about this model RPM standards?
I'll try with a fuel injector cleaner product. Any recommendation?
Old 10-15-2014, 11:42 PM   #12
sheekeebut
Minimalist
Sorry, can't help you there. I find most of my problems dealing with idle lie just before throttle body. Battery? Alternator?
Old 10-16-2014, 12:08 AM   #13
Mika
Drives: Yaris 2007
Look what I found in the repair manual . I knew I wasn't crazy... Definitely, something is wrong.
Manual trans and Automatic trans idling speed:
File Type: gif 2014-10-15 23_06_22-Service_Specifications.pdf - Adobe Reader.gif (6.8 KB, 339 views)
Old 10-16-2014, 12:45 AM   #14
sheekeebut
Minimalist
Useful! Well, that might be some reassurance to me, I've been holding back on changing my battery for some time now.
Any new leads?
Old 10-21-2014, 10:24 AM   #15
Mika
Drives: Yaris 2007
I poured a bottle of STP fuel injector cleaner today, in a full gas tank. Let's see what happen...
Old 11-13-2014, 04:28 PM   #16
Mika
Drives: Yaris 2007
Sorry for the delay. Nothing have changed after pouring the fuel injector cleaner.
My next step is try with Auto Centro Toyota, here in Puerto Rico. Wish me luck!
Old 11-14-2014, 01:54 AM   #17
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
If there is not enough power from battery/alternator the ac clutch will not kick in. Hence the warm air. Perhaps at higher rpm when car is moving enough juice is generated to engage ac clutch.
Toolaholic is offline   Reply With Quote
Old 11-14-2014, 02:54 AM   #18
kustomrtr
kustomrtr's Avatar
Drives: 2k7 Yaris
Hey, I just wanted to say that I have the same exact issue you're describing. Same low rpm and the ac starts blowing warm air.
I have 6 months with this issue. I changed the fuel pump, spark plugs, air filter, cleaned the MAF, cleaned the throttle body,etc but I'm still having the same issue.
If you find out what the problem is, please update this thread. I'll let you know if I fix it!
Saludos
Current Mods:
aFe Cold Air Intake | Tanabe Medalion Touring (decatted) | TEIN S-Tech Lowering Springs
3000k HID fog lights | HID Custom Headlight Retrofit | Hellas Supertones | Ralco Short Shifter.
To-do list:
Lightened NST Pulleys | DC Sports Headers | TEIN Street Advance Coilovers
kustomrtr is offline   Reply With Quote
a/c, idle, rpm, speed
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
Rims + tires for a 2007 Yaris sedan Shmomi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-18-2011 05:03 PM
