Old 08-17-2016, 01:26 PM   #1
UpLateAgain
Drives: 2008 Yaris automatic
Need ECU help
Hi all,
Got an '08 base model hatchback with A/T, that the alternator went out on. Mechanical issue. Grinding when turning. I replaced the alternator, reconnected the battery, and when I went to start it up had new set of problems. Dash lights came on, and the car started just fine, but the whole set of dash and warning lights remain on when it is running, the shift lock won't disengage (leaving me stuck in park), and the engine only idles.... it won't accelerate. I turned it off, connected a code reader, and switched it back to the on position. The code reader will not communicate with the ECM. Just tells me it's not connected.
If it is the ECM, can I just replace it with a used one of the same part number (89661-52G40), or do I have to have it reprogrammed. If it's not the ECM, can anyone suggest where else I can look for the fault? Not being able to move the car because of the engaged shift lock is a real pain.
TIA
UpLateAgain is offline   Reply With Quote
Tags
alternator swap, ecm, shift lock
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 10:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 05:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 07:15 PM
