Old 10-21-2016, 10:13 AM   #1
DallasYar
Drives: 2007 Yaris Sedan
Yaris making wide right turns and now flat tire
2007 Yaris Sedan has flat tire on rear passenger side which isn't 100% flat but still has about 10% air. Passenger front is also somewhat flat but has about 90% air.
Could this be related to the car making excessively wide right turns and being wobbly while driving straight? Could this be a tie rod end problem? Or perhaps coil/suspension or even an axle? Can these type of problems result in excessive wear on tires causing tire leakage?
The car only has 31,000, about 18,000 I put myself over the last 1.5 years. Bought from an elderly person who rarely drove it.
The mileage is really on the tires to have them wear out so quickly based on these hypothetical issues with axle, suspension, tie rod ends etc? True?
also, in a general sense, are wide right (or left) turns caused by tie rod ends going bad, or something else?
thanks for any help.
DallasYar is offline   Reply With Quote
