Old 12-01-2016, 02:16 PM   #1
esse10
Drives: 2009 yaris 2 door
squeal or screetch
heard a high pitch screech/squeal coming from the motor area during high RPM shifting today. It almost sounded like bearings going bad or something, only did it for a few seconds while high rpm shifting, then went away. Anybody have a clue what is going on here? water pump bearings , alternator bearings ?
Old 12-01-2016, 04:09 PM   #2
Before speculating on anything as radical as bad bearings, I'd suspect belt slippage. Bearings would make themselves known under far more circumstances than high rpm shifts.
Old 12-02-2016, 12:33 AM   #3
SirDigby
Drives: 2007 yaris 3 door
it was probably just your tires spinning under the ultimate engine torque. watch that beast!
Old 12-03-2016, 02:48 PM   #4
esse10
bearings
well I've heard bearings and fans luck up before and it almost sounded like it. I know how a belt sounds when it sqeeks and it didn't seem like that. I haven't heard it ever since I held back on THAT BEAST. LOL
I'm shifting at a lower rpm to make sure.
thanks for the input folks.
Old 12-10-2016, 07:13 PM   #5
jra
Drives: 2015 yaris L
Car telling you in Japanese, please don't drive me so hard? Most likely a belt, could be the throw out bearing or clutch complaining, but I doubt it.
jra is offline   Reply With Quote
Intermitent Clutch (i think) Squeal alex22808 DIY / Maintenance / Service 12 10-23-2014 07:04 PM
07 HB Mechanical Noise Cold Squeal Fidelio DIY / Maintenance / Service 0 09-12-2012 11:29 PM
squeal on startup (audio) N9QGS DIY / Maintenance / Service 5 10-21-2009 12:42 PM
Brakes squeal. AlexNet0 DIY / Maintenance / Service 11 05-01-2009 03:47 PM
