![]() Drives: 2013 Yaris LE 5 door hatchback Join Date: Jan 2017
Voltage regulator or new Alternator?
My wife's 2013 Yaris is only charging at slightly above 12v. I had it tested and was told battery was fine but regulator in the alternator was bad.Has anyone taken one apart and replaced just the regulator? The car has 173k miles on it so i am thinking it would just be best to replace the entire unit.Or would it be ok to just replace the regulator? I have np taking it apart if so.
That being said,I am currently furloughed and trying to save where I can.Is there a brand suggested? Thanks! |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Try cleaning the voltage regulator.
You can try a re builder but the price maybe the same as a complete rebuild. CT Scott was advertising a used one for $35 in the for sale section. |
Good advice by nortonfb. If it were me, I'd pick up CTScott's alternator. You can be guaranteed that, since it comes from him, it will be in great shape and fully functional. When my charging started failing, I had my voltage regulator out and could see the obvious corrosion that they are known for. I just replaced the unit with a CarQuest reman and it's worked flawlessly for years now. I think it might even have a limited lifetime warranty.
Thanks.ill send him a PM
| Alternator voltage | Ramon1691 | DIY / Maintenance / Service | 5 | 11-20-2016 11:15 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| 2003 Yaris High Alternator Voltage | drcurzon | DIY / Maintenance / Service | 3 | 05-22-2012 04:16 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| possible alternator (voltage regulator) issue | jesse1000 | Canada | 3 | 03-09-2009 09:10 PM |
