![]() ![]() Drives: Yaris 07 HB Join Date: Apr 2011
Problems with OEM Lock Switch
Hi,
Recently I buy a OEM lock switch for ma yaris a 2007 hatchback. The car have the factory locking system, the only thing that a miss is the switch in the center console. The Problems I install the switch and nothing happen. No lock/unlock the doors. What that i miss! Any help please! Sent from my iPhone using Tapatalk |
![]() ![]() Drives: 47 2013 yaris l hatchbacks Join Date: Nov 2016
Lock switch? Can you expand on that? The lock cylinder in the door? The power door lock driver? Why did you replace it's part. What was the problem before you replaced part xxxx?
Sent from my SAMSUNG-SM-N900A using Tapatalk |
![]() This little thin. Sent from my iPhone using Tapatalk |
Fuse?
Try looking at fuse#39 in the under dash fuse box.
I'm still a bit confused on your post. Was the system intact and working at one point?
If you didn't have the switch in the console (hatchback), then you do not have a factory system.
What tells you have factory powered door locks? Sent from my SM-G930W8 using Tapatalk |
Because in the doors come withs this with plugs:
![]() And in the rear hatch come with one too Sent from my iPhone using Tapatalk |
Because that is in the door and trunk does not mean it was installed, oe, or at any time working. Copy down your vin number and go to your local toyota dealer parts department and ask them if that vin came with factory locks or not. If you can't get info from them try searching a vin decoder in the forums. I'm sure you will find some posts to a good one that can provide the info. Also if you have the origonal sticker that came with the car that will help. It would be listed as an option there. If for some reason you exhaust all those options first let me know. I will get a wiring diagram and component located and help you.
| DIY - OEM Power Window Conversion | CTScott | DIY / Maintenance / Service | 29 | 10-28-2024 12:02 AM |
| Doors Won't Lock | TutorMe | DIY / Maintenance / Service | 3 | 08-05-2014 04:04 PM |
| Ultimate yaris part out, aftermarket and OEM | yaris rs | Items for Sale by private party | 25 | 06-20-2011 01:43 PM |
| how can I add a power lock switch? | gabriel2012 | DIY / Maintenance / Service | 10 | 01-01-2011 09:08 PM |
| OEM Parts | hatchbackkid82 | Items for Sale by private party | 30 | 12-17-2009 11:08 AM |
