Old 02-03-2017, 01:10 AM   #1
mamun22s
Drives: Toyota Vitz
Idle gradually decrease
I have a vitz 2000, 2NZ-FE. Recently, I replace a the engine from a after market. I have faced a new problem. Car idle decrease gradually decrease. And one of servicing person suggest me to open (-) battery terminal and reconnect after 5 minute. That actually solve my problem temporary. After run the car around next 100 km same problem arise again and engine stall on idle. There is no error code on OBD.
Can any one suggest me the reason and the solution.
-Thanks
Mamun
mamun22s is offline   Reply With Quote
Old 02-03-2017, 04:53 AM   #2
lupetnen
scph/jdmuph
Drives: toyota vios ncp42
hi mamun seems to me you have a dying fuel pump if the engine gradually decreases in idle.
lupetnen is offline   Reply With Quote
Old 02-03-2017, 06:49 AM   #3
mamun22s
Drives: Toyota Vitz
Thanks lupetnen for your replay. As I mention my problem totally solve after (-) battery port for few days. If it is for fuel pump it would happen always. But once after I open (-) battery port everything going normal for few days.
Old 02-03-2017, 09:46 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The throttle stop might be set to low on that motor. What RPM does it idle at? Can you make a short video?
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 02:39 AM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 04:08 PM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 01:48 PM
