Old 07-17-2016, 09:26 AM   #1
Pinchlite
Drives: 2007 yaris HB
Terrible Fm reception aftermarket radio/stereo
I read somewhere the antenna has a booster and needs power.I have 2007 Yaris.Something about connecting blue wire to ?
Hopefully someone knows waht the issue is.The stock deck had fantastic reception.Thanks
Pinchlite is offline   Reply With Quote
Old 07-18-2016, 08:16 PM   #2
sickpuppy1
Drives: 2010 Yaris Sedan
there us a blue antenna lead like power antenna from your head unit. that should go to a blue wire from your antenna. yes the stock radio antenna needs this power to work.
Old 07-18-2016, 10:28 PM   #3
Pinchlite
Antenna
I do get fm stations but very bad range/reception.I will pull deck and see whats up.Thanks for reply.
I believe I need to use the power retractable antenna wire from headunit which is 12 volts.
Old 07-20-2016, 12:20 PM   #4
Kar98
Drives: 2011 Scion tC
Yup.
Kar98 is offline   Reply With Quote
Old 07-20-2016, 06:44 PM   #5
Pinchlite
I dont see antenna power wire labeled on the stock yaris harness connecter.
Old 08-07-2016, 08:27 PM   #6
Pinchlite
Originally Posted by Kar98 View Post
Yup.
Did this and no change.
Old 08-07-2016, 08:19 PM   #7
Pinchlite
I used the power antenna power from headunit to blue yaris antenna wire.
No diffence in reception.I may get a better hedunit
Old 08-07-2016, 08:25 PM   #8
Pinchlite
Did this but no difference.Why does the yaris suck for fm.My other cars had good reception with aftermarket radio.
Old 07-20-2016, 08:45 PM   #9
Black wire I believe. Long time since I'd done mine.
http://www.yarisworld.com/forums/sho...5&postcount=30
Old 07-21-2016, 02:20 PM   #10
Pinchlite
FM
Thanks bud.I will definitly get it sorted this weekend.
Old 07-23-2016, 02:38 PM   #11
jayeh
Drives: '08 Yaris LB
I was having the same issue! Thanks for the info guys!
jayeh is offline   Reply With Quote
Old 07-24-2016, 11:32 PM   #12
Pinchlite
Let me know how it goes.I had zero personal time this weekend like usual so did not get to it.Thanks.
Old 07-31-2016, 08:52 PM   #13
bassmannate
Drives: 2008 Toyota Yaris
Should be blue or blue/white. I always get them mixed up. Your aftermarket head unit should only have 1 though. If the adaptor harness has both of those, just connect them both to the one.
bassmannate is offline   Reply With Quote
Old 08-07-2016, 08:21 PM   #14
Pinchlite
I did this but no difference in reception.
I will try somesort of antenna booster/amplifier and if that doesnt work then I will get better headunit.Actually tempted to put the stock unit back in.
Old 03-07-2017, 06:52 PM   #15
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
hmm this is worrying
Cartel is offline   Reply With Quote
Old 03-07-2017, 06:58 PM   #16
Pinchlite
From what I have read Its a known issue just not with yaris but other cars aswell using aftermarket headunit.
my headunit is a good quality Pioneer doubledin.
I just dont use the radio.
I did this but did not improve.
http://www.custommagnums.com/forums/...nit-fixed.html
2012 YARIS HB poor radio reception code54 In Car Entertainment + Electronics (audio / video / alarm) 5 12-19-2015 11:46 AM
Radio Reception kimona Third Gen Yaris General Discussion 15 12-13-2015 11:46 PM
Better FM reception with stock radio? unadilla66 In Car Entertainment + Electronics (audio / video / alarm) 7 06-23-2015 06:56 AM
Fix for poor reception SpaceShot In Car Entertainment + Electronics (audio / video / alarm) 6 01-12-2015 11:42 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 07:50 PM
