Old 10-13-2016, 09:45 PM   #1
KenTK808
Drives: 2014 Yaris LE
Turbo 3rd Gen In Progress
Started piecing together a budget turbo build for my 2014 Yaris! My goal is to get a very street-able setup that will last me awhile.
So far I have a Garrett T25 (SR20DET) with a fresh rebuild (turbo was free rebuild was $200)
A Zage style cast turbo manifold ($80)
A tiny inter-cooler I had laying around from my old Honda
Walboro 255 from a friend
2ZZ Injectors ($60 on craigslist)
oil and coolant lines I have but will probably need to order new ones
boost gauge i had
V-band down pipe flange for a custom DP ($40)
silicone pipe connectors i had
The list of things I need is long and so are the questions I have lol
What did you guys do as far as inter-cooler piping?
What are you guys running as far as EMS? The budget I have is mostly going to be spent on tuning.
KenTK808 is offline   Reply With Quote
Old 10-22-2016, 05:22 PM   #2
BennyLava
Drives: 1987 Silverado
Any progress since your OP? I am definitely looking forward to seeing the results. As well as knowing your final cost for the whole thing.
Old 10-22-2016, 07:09 PM   #3
KenTK808
Sorry mate, still piecing it together. got the turbo and manifold test fitted on a spare motor I have. Looks like the most irritating part is going to be the plumbing of the charge pipes.
Old 10-22-2016, 08:50 PM   #4
BennyLava
What is the most pressure you'd go? You're doing this on a stock engine, right? Other than having to get the computer reprogrammed. I'm looking into turbo'ing my 2009 sedan. But I also want it to last.
Old 10-23-2016, 09:11 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
in general around 7 psi is the normal max for stock internals. The "computer reprogrammed" isn't really an option with Toyota as the only company that can get that deep into the computer is Tom's in Japan, to turbo you either need a piggy back system or a full stand-alone.
it has been said that a low boost system only doing 2.5 psi or less can be done with out any additional controls, but that is generally just a tease that make it to hard to not turn it up imo.
Old 10-26-2016, 03:47 PM   #6
BennyLava
The piggy back doesn't sound so bad. How is that done, and is it expensive?
Old 10-27-2016, 12:34 AM   #7
KenTK808
Ask your tuner for advice. My tuner told me that spending the extra money on the full stand alone might save my motor and they usually come with a shit ton of more features IE launch control, anti-lag, boost by gear, electronic boost control comparability, Wideband AFR support and wide map resolution
Old 10-27-2016, 12:37 AM   #8
KenTK808
The motor will be stock yes, I'm seriously considering swapping out the head-gasket for a thicker all metal gasket to lower the compression a tad. Usable and street-able power is my goal here. Not looking to beat evo's although with 160 wheel hp, I'm sure I could make some FRS/BRZ and S2000 guys salty.
Old 12-07-2016, 06:20 AM   #9
Tima122
Drives: bB NCP 31 2005 y
https://youtu.be/ndNuW7q4CEk
Turbocharger -Nissan Silvia s13
Toyota bb, 1Nz, in/ex jun 264
Tima122 is offline   Reply With Quote
Old 03-07-2017, 03:38 PM   #10
Mahfuz11
Drives: 2011 Vitz RS G'S
Any progress ?
Mahfuz11 is offline   Reply With Quote
DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) CTScott DIY / Maintenance / Service 12 01-22-2022 04:09 AM
2nd vs 3rd gen ride quality + durability chocolab Third Gen Yaris General Discussion 23 11-17-2014 08:30 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 09:16 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
