Old 04-19-2017, 04:26 PM   #1
SteveKran
Drives: 2012 Yaris
2012 Yaris L - Aux/USB input?
Just curious if the base Yaris L has the Aux/USB input in the glovebox?
I'm about to drive pick up a 2012 Yaris L and drive it 12 hours home....just trying to plan ahead.
I'm already going to install the cruise control.
Thanks!
SteveKran is offline   Reply With Quote
Old 04-19-2017, 04:31 PM   #2
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
mine does, and its about as base as you can get (manual transmission and windows)
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 04-19-2017, 04:37 PM   #3
SteveKran
Drives: 2012 Yaris
Thanks!
Mine is auto tranny, but has manual windows
Old 04-19-2017, 04:40 PM   #4
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Originally Posted by SteveKran View Post
Thanks!
Mine is a 2014 LE and I moved the USB/aux input from the glovebox to the center console by the hand brake. I understand the idea behind putting it there, but I hated it there. So I moved it.
m.flores.0928 is offline   Reply With Quote
Old 04-19-2017, 04:54 PM   #5
SteveKran
Drives: 2012 Yaris
I like that idea too....sounds like a better place than the glovebox
Old 04-19-2017, 05:02 PM   #6
m.flores.0928
Drives: 2014 Yaris
It was a pain to move it, so heads up. Remove the glovebox, the passenger side dash cover, the stereo head unit, climate control panel with knobs, and center console, then pop out the USB connector, set it aside, separate its wires from that portion of the wiring harness (careful, there are airbag wires in there) and route them back and down behind the head unit and climate controls area, and under the center console along the shifter mechanism. The square USB connector fits right in those blank square pieces by the hand brake. The wires are JUST barely long enough to reach there when you separate them from the wiring harness. Once everything is set in place, I recommend you tie the harness back up so the wires aren't just dangling around.
Old 04-19-2017, 08:10 PM   #7
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
My wife has a 2012 L. It has the auxiliary input and USB in the glove box and her's didn't even come with Bluetooth lol
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
2007 yaris snow tires on 2012 lomky Third Gen Yaris General Discussion 4 11-16-2012 03:00 AM
European Yaris TS 2012? Jochen Third Gen Yaris General Discussion 17 04-19-2011 01:43 PM
