![]() Drives: 2004 Echo RS Join Date: May 2017
Will a Yaris Supercharger fit on an Echo?
I'm curious about this because I saw a used Blitz supercharger for a Yaris. Would it fit on an Echo without significant changes?
it's the same engine. i would think it would fit the same...
2ZR swap. DO IT! Ask how!
The compressor and plenum will fit. The intake tube is application specific because the Echo has a 3-bolt throttle body, the Yaris has a 4-bolt. There are varying reports of the alternator bracket having 2 different designs, so you'd need to look around the forums a bit more to get a definite answer.
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
The echo 1NZ has a different upper oil pan then the yaris does...I found that out when trying to order an engine. It changes the alternator mounting points so I would have to think the bracket for the S/C bits wouldn't work on the echo
05' Echo Hatch - Greddy Supercharger - rear disc |
| Be honest, if you could go back in time and do it again..... | bentjazz | General Yaris / Vitz Discussion | 127 | 02-25-2013 04:11 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 12:03 PM |
| 05 Echo RS or 08 Yaris RS? | tawheed | General Yaris / Vitz Discussion | 18 | 01-06-2011 04:27 PM |
