![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
12 Hours of Cleaning!
so i have never taken care of the paint on any vehicle i have owned, and they all suffered because of it. i've had the yaris for a year, and the paint looks so good that i decided i would attempt to take care of it.
these are the chemicals that i used: Chemical Guys: V36 cutting polish, V38 optical grade polish, Mr. Pink shampoo, White Light sealant, white paste wax, O-High Shine dressing, medium grade claybar mitt + lube Meguiar's: DA drill attached polisher, compound/polish/wax pads generic microfiber washing mitt and a stack of microfiber towels holly crap!!! procedure: wash (with dawn), clay bar mitt (lube smells so awesome!), wash with Mr. Pink (smells like watermelon candy, yum!), cut with V36, polish with V38. then it was 7pm. damn! that took 6 hours. next day: wash and clay again with Mr. Pink. Seal with White Light. wait 30 minutes. buff off. wax with White wax. buffed off. treated all black plastic and rubber seals with O-High Shine. (also smells great!) these products all worked well, very well. better than i ever expected. and they all smell so good! when i was using the cutter (V36) on the roof, there was so much oxidation and smog and crap in the pant that it looked like mud running off. it was so gross, and it was after 2 washes and clay bar-ing. here is some before pictures: After all the work, the pictures do not give justice. i notice that it's so shiny that the camera misses a bunch of the body lines. but it is so super shiny and smooth. ...so smooth yeah, it's soooo much more shiny than the pictures give justice. these Chemical Guys chemicals worked well. extremely happy! |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
I know the feeling. Whenever I wash+wax+detail my car fully, it takes a big chunk out of my designated Sunday morning+afternoon.
Good job on the cleaning/detailing - it doesn't look anywhere near 10 years old. |
![]() ![]() Drives: 2008 HB Join Date: Dec 2012
Now clean the windshield like this, you'll love the results
https://www.youtube.com/watch?v=aVUtdlzrktI Steve |
Looks good! Get yourself some Mcguire's ultimate quick detailer and every couple days use it to wipe off any dust and light dirt. Your car will look like it does now and for only 10 mins of time.
Most of keeping a car looking like that it being constant on maintaining it
i did clay bar the glass. and i have always applied rain-x twice a year on all my cars since i was a teenager. i live next to the mountains and they use gravel on the roads. i have glass coverage because it's pretty common to get a new windshield every 6 months to a year. i don't want to spent hours polishing glass that could need changing on a daily basis.
but if i had a car that only got driven like once a month, this is a great idea for your fancy car! |
today i had a microfiber towel with me, and every time i would stop, i would be a dirty spot where there was wax build-up that i missed. it happened like 3 times. i think i got it all now...?
Great job. Always nice to see other people doing full details on their cars.
What I noticed with CG products is that they only play nicely with other CG products. That's why I decided against using them. I don't recommend using Dawn/dish soap to prep the surfaces to be detailed. Dish soap can dry out plastics and rubber trims, which I experienced with my Vios. I never did it again after that. However, you did treat the plastic/rubber, so that should help. Clay barring is sufficient in prepping the surface for any compounds. A dedicated wax remover can also be used. I stopped using Rain-x and just use my wax (Collinite 476s) on my windows. Does a much better job at actually beading off water than Rain-x, and lasts WAAAAY longer. I actually don't use my wipers unless it's misty. Rain just beads off at 30+ mph. On other suggestion for you for next year (or the next time you do a full detail) since you have a white car. Use CarPro Iron-x to remove any rail dust/iron contaminant from the paint. You should wear gloves and a respirator for this since it smells like skunk spray. |
Also, I take it your car is swirl-free now?
![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
looks good
uh....i guess so. i didn't really see any swirls on the white before. it was mostly just faded and had minimal reflection, very minimal. i just wanted it to be super shiny. (now, i found like 10 little dents here and there)
it was mostly the roof and hood dullness that was bothering me. i might go over them again in a couple of weeks... oh, and the CG O-High shine worked great! my cowl was all grey and super faded and awful looking. i hadn't even noticed. now it's all black and looks like it's new and wet! it didn't work so great on the b-pillar plastics, but that might be reacting with hand oils and stuff. i'm not sure why, maybe it just needs a few coats. worked good on mirror plastics. |
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
Looks real nice!
I've noticed that the plastic on the door, behind the window (what you called the b-pillar plastics) is somehow different than all the other plastic on the car. I use Aerospace 303 on all my plastic, inside and out, and it works really well everywhere except there, where it leaves a weird, smudgy, oily-rainbow sheen. It must be some different sort of plastic that won't absorb anything. |
yeah! rainbow oily gross. maybe i'll go get it vinyl wrapped...
Hatchbacks for the win
Drives: Hatchbacks Join Date: Aug 2006
In the before pictures you have stock tail lights, then after your wash/wax it has JDM tail lights. Hell yeah! I hope that happens when I wash and wax my car. :)
#14 |
Ha, nice catch. Made me notice the change in wheels too; from hubcaps to trim rings.
#15 |
you almost got them all.
also: S spoiler, micro vortex generators, lower grill mesh, netz badge, and painted upper grill and fog light grills. they all went on before waxing...and those beauty rings are metal, not plastic :) |
| Tags |
| chemical guys, clean, detail, wash, wax |
| Fuel System Cleaning? | naossoan | DIY / Maintenance / Service | 8 | 02-25-2014 10:43 PM |
| Cleaning factory CD player? | DebbyM46227 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 09-17-2013 09:31 PM |
| Does EFI cleaning helps with mileage? | caineroad | Fuel Economy Forum | 20 | 03-21-2013 08:05 AM |
| cleaning fabric door panels | dmfang | Wash, Wax, Detailing, Exterior Repairs | 4 | 10-16-2012 10:41 PM |
| Cleaning throttle body | ToTo | Performance Modifications | 18 | 07-27-2011 05:20 PM |
