Old 03-18-2017, 12:21 PM   #1
frank2005
Drives: Toyota Echo RS 2005
Trailer with echo 2005 HB tow capacity ?
Hello,
I call Uhaul max trailer size is 5x8
little move with toyota echo hb ?
Load 800LBS MAX ?
Overweight
Risk broken the chassis?
frank2005 is offline   Reply With Quote
Old 07-09-2017, 07:47 AM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
nope, yer good
use 3rd gear, no 4th on heavier loads
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 07-20-2017, 09:07 AM   #3
praivo
Drives: 2000 SCP10, 2001 NCP13
I've towed 1400+ lbs (and once over 1600) multiple times with no issues.
praivo is offline   Reply With Quote
Old 07-20-2017, 04:14 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I have a 2012 Yaris, so these figures may be a bit different for your echo.
The Australian manual for the Yaris lists a maximum trailer weight of 900 kg (1984 lb). This is reduced to 550 kg (1216 lb) if the trailer does not have brakes.
800 lbs is well within the capability of the Echo or Yaris.
2005 Echo RS Cluster in a 3DR 2004 Echo Liftback . mpcv2000 Canada 73 05-20-2021 08:14 AM
Hi im new here i bought Toyota echo RS 2005 frank2005 General Yaris / Vitz Discussion 21 12-12-2016 10:27 PM
Toyota Echo 2005 RS Performance Upgrade Help tattoo007 Canada 4 03-10-2016 10:30 AM
2005 Echo RS Performance Upgrade Help Required!! tattoo007 Performance Modifications 2 03-08-2016 07:24 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 04:23 PM
