![]() ![]() Drives: Yaris MK3 1.33L Dual VVT-i CVT Join Date: Jun 2014
KENWOOD KSC-SW11 on Yaris 2013
Hi
Im planning to install Kenwood KSC-SW11 on my Toyota Yaris 2013 5 door. 001.jpg This is the wiring diagram for the same subwoofer. I have the pin diagram for Touch and Go 20171021_183011.jpg As explained in the pin diagram pin no 3 on 10 pin connector should connect to Blue/White wire from subwoofer (Accessory line 12V) subwoofer front/rear left go to pin no 2,6 on 10 pin connector or pin no 2,6 on 6 pin connector and subwoofer front/rear right go to pin no 1,5 on 10 pin connector or pin no 1,3 on 6 pin conncector *Front or Rear which one will give better output for subwoofer Black wire from sub is ground. Yellow wire from sub go to fuse box + Could you please help me to find which one is that fuse box and how to connect. Also any one please confirm the above explained is correct method. |
eh, i have a SW10 and installed an SW11 not long ago to a scion xd. I used a thicker cable and connected the yellow direct to the cable, which is connected direct to the battery terminal under the hood.
The kit allows you to use the yellow with fuse and connect direct to battery, there's more than enough slack to do so. |
#3 | |
pins look good, I used aftermarket headunits so i connected the sub with stereo RCA cables. If you're splicing the stock radio, I would do fronts, especially if you're dropping the sub under front passenger seat.
I got this cable from Halfords , so it was easy for me to connect the sub cables. |
| Tags |
| 2013, digram, subwoofer, wiring, yaris |
| 2013 Yaris SE - What to mod? | roachslayer | Third Gen Yaris General Discussion | 9 | 05-07-2017 05:56 AM |
| 2013 Yaris headliner for sale | Smog7 | Items for Sale by private party | 4 | 03-04-2017 11:53 PM |
| rear spring replacement 2013 Toyota Yaris (NCP130) | williew2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 02-27-2017 01:46 AM |
