Old 10-03-2017, 07:11 AM   #1
Spellino
Drives: Toyota Yaris 2007 Sedan
Disturbing Noise
Hi everyone. On my 2007 Sedan, there is this very disturbing sound that appears to come from under the engine bay or under the car when I step on the accelerator in low gears.
It sounds like a rattling or two metals vibrating against each other. It only happens when im driving slowly and especially when I'm climbing even the smallest hill.
By the way, it's an automatic.
What could be the cause?
Spellino is offline   Reply With Quote
Old 10-03-2017, 08:26 AM   #2
ex-x-fire
Exhaust shield? You'll have to get under there to check it out, if you can't then take it to a shop.
Old 10-03-2017, 07:23 PM   #3
Spellino
What would I be looking for?
Old 10-06-2017, 06:49 PM   #4
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Follow your exhaust under the car and into the engine bay, it's a small piece of stamped metal that in places sits around your exhaust to help with heat.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 10-09-2017, 09:43 PM   #5
xdarkxfirex
Drives: 2015 yaris le
Yea, you can take it off, I just tied mine at the bottom with some wire.
xdarkxfirex is offline   Reply With Quote
Old 10-03-2017, 09:37 AM   #6
tmontague
tmontague's Avatar
^agreed, tends to rattle more under load at lower rpms ie: a/c on while at idle
Old 10-03-2017, 04:20 PM   #7
fourbangingfun
fourbangingfun's Avatar
It’s probably the heat shield on the header. Mine rattled when idling with the AC on. I just took it off. No problems.
fourbangingfun is offline   Reply With Quote
Old 10-03-2017, 07:24 PM   #8
Spellino
My AC doesn't even work so I don't know
Old 10-03-2017, 05:56 PM   #9
hairygityeti
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg
Unhappy
I have a similar thing coming from the pully side,i think mine maybe the water pump. I hope its the water pump as the alternatives are too expensive.
If it wasnt for my modesty ,i would be perfect !
hairygityeti is offline   Reply With Quote
shh shh shh noise at tickover monkeydave DIY / Maintenance / Service 0 08-16-2017 08:44 PM
Colour Collection 05 Reg (UK) brake noise JLx DIY / Maintenance / Service 0 07-14-2015 07:56 AM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 01:20 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 01:27 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 05:21 PM
