Old 06-29-2018, 12:48 PM   #1
cherrmj
Drives: 2010 2Dr
P2401 2010 Yaris Hatchback 90K Quick Pass
Hello, My Daughter is out of state and is coming home for a visit and to have the car emission tested. Will only be in town for five days and of course CEL this week. Code P2401 She said over the last few months it would come on and off every week or so. We talked about over fuel filling and securing the cap. I've read may posts here and elsewhere and cause could be entire EVAP Canister or components or cap or vacuum or.... water in system.... short notice I can not afford new EVAP, Rockauto $525 and not enough time.
I only have a few days and I'm looking for some basic things to try so it can pass for now and address real fix when out of state. In a bit of a panic and just need a Pass on the test for now. Add some HEET if water in tank or ???
Please help me Pass the test!! Thank you very much!!
cherrmj is offline   Reply With Quote
Old 06-29-2018, 02:03 PM   #2
atomic_hoji
Drives: 2018 Yaris SE 5MT
Quick check of the gas cap o-ring? I've had a a MIL/CEL come on for evap. related issues (sorry, don't recall if it was the same code) on a car and found the o-ring was a little old and dry looking. I took it off, lubed it with a bit of grease, and rolled in back in place with the inner side facing out - so the older, dry side that had been facing out was now in. Worked a treat for a while.. Worth a try if you're in a pinch.
Good luck with it, and let us know if you get it solved.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 06-29-2018, 02:30 PM   #3
cherrmj
Drives: 2010 2Dr
Thanks will have her check the gas cap O-Ring. Other suggestions? I think I need to cast a wide net
2010 Toyota Yaris LE Hatchback Bulb Size xmotionx Cosmetic Modifications (Exterior/Interior) 0 01-16-2014 03:46 AM
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 01:06 AM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 03:57 PM
