Spacers have arrived!
Very happy to receive a Canada Post notification that my parts have arrived. Thanks, invader166! Loved the 'refreshing looking' shipping box, too!
The 08 goes into the shop tomorrow to get the H&R 10 mm spacers put on. Here's hoping the longer studs will go in without having to remove the hub. Fingers crossed. If hub removal is necessary, it will just be good paractice for putting the Penguin spacers on the '06, which is the next job. ![]()
Beauty. Supplied studs appear to be of a length that will not cause issues when it comes to putting them in there.
#3 | |
Pic... Can you confirm WeeYari, that these will indeed go in without removing the hub? Of course, I won't hold it against you if I can't get them in due to my mechanical ineptitude, LOL! Not sure what the longer greyish bolts on the right are for.
Don't need one. Can clearly see they are a good length.
Spacers installed
I made a collossal screw up. After removing the drum to replaced the studs, I forgot to replace the drum and attempted to install the spacers directly to the wheel hub. Anyway, I had to machine lathe out a bit of the lip inside the spacer bore to make it fit I wasn't thinking. Bolted it all back together and went for a drive. It drove fine, but had an almost imperceptible bit of wheel wobble when looking at it in the mirror. Back to shop, realizing what I'd done and put the spacer outside this time. I hadn't removed enough material to make the hub bore loose. The other side, I did properly.
The studs went in easily with a bit of fiddling. On to the pics. Although they don't show the difference really well, in person it does look much better and more obvious. 3 new long studs installed. Rear brake job tomorrow. :) ![]() Top, before spacers, bottom after... ![]() Top, before spacers, bottom after... ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 04-30-2018 at 05:40 PM. |
Yup. Noticeable difference.
Haha, glad someone else could see the difference. The kids in the shop all laughed that someone would put spacers on a Yaris. Of course, they're mostly into big off-roading trucks and such and only feel that such vehicles deserve spacers.
The '06 will be getting its Penguin spacers installed in a few weeks.
#9 | |
![]() Drives: Yaris hatchback 06 Join Date: Nov 2018
Possible to take measure of length of stock wheel stud? On rockauto they have one with 40mm tread length. I need 8stud with only 2mm more length. The wheel i buy the hub was too thickness
| Wheel hub spacers be warned! | tmontague | Performance Modifications | 17 | 07-07-2016 10:56 PM |
| PG Hub spacers group buy | Vitz_Q8 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 11-15-2015 03:10 AM |
| FS: Hub Spacers (R) /Wheel Spacers (F). Come with extended bolts. | Betrivent | Items for Sale by private party | 1 | 06-26-2015 11:41 PM |
| Wheel spacers walkthrough :) | Lars | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 06-05-2014 09:49 AM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 08:10 PM |
