Old 12-15-2017, 05:25 AM   #1
TacoJim
Drives: 2007 Toyota yaris
Heater problem
This morning it was 5 degrees and the car just wasn't getting warm fast enough so I thought if I turned the heater from fresh to recirculate it would get warm faster. I turned the knob on my 07 yaris and it was a little hard to turn til I heard a pop and a something bouncing around in my dash. Now the knob turns like nothing is there. Is there a cable or something that connects back there and if so does the whole dash have to come apart to fix it?
TacoJim is offline   Reply With Quote
Old 12-15-2017, 07:09 AM   #2
tmontague
tmontague's Avatar
This issue is discussed in detail in various threads. Try the search function and you'll find your answer there.
Once you reconnect it (after removing a few pop off panels) to avoid it from happening in the future if you feel that resistance next time you turn the knob stop and keep trying but more gently. Eventually the blend door will flip with less resistance and the cable won't diconnect from the knob.
It's a poor design flaw and is a pita until your get a feel for how to turn the know and know if it going to disconnect or not
Old 12-15-2017, 08:32 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Don't touch cold roto-cable Yaris HVAC knobs. Mind of Toyota
Catch 22--Plastic HVAC control cable housing shrinks and is stiffer the colder it gets. Lube and elastomers and all parts of the system are stiffer and more brittle. A bit of water turned ice on a flap seal sticks it tight. Don't try to move any of it until it warms up? (Seriously. Consider turning off the blower before shutdown, and leaving all the big cable-knobs where you want them for best defrost on the next cold start.)
(Don't touch cold roto-cable Yaris HVAC knobs. Mind of Toyota)
Old 12-15-2017, 04:14 PM   #4
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I would have to say that the climate control system is among my least favorite features of the US/NA-spec Yaris. The A/C works fine, don't know about the heat because I have never used it here in southern AZ - but the knobs/controls are just about as low-rent as you can get. Other markets have a much nicer climate control setup available in the Yaris/Vitz. At the very least, the SE trim should get the upgraded controls here in the US/NA market.
Kalispel is offline   Reply With Quote
a.c., fresh air, heat, heater, recirc
Super weird Yaris 2003 A/C problem zoharby DIY / Maintenance / Service 13 06-22-2017 12:14 PM
Starting problem Muz Suggestions - Feedback - Questions 2 05-06-2017 06:31 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
headlight problem kenkyd Cosmetic Modifications (Exterior/Interior) 2 02-12-2010 07:55 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
