![]() ![]() Drives: Yaris 1.33 vvti 2015 Join Date: Nov 2014
Yaris 2015 Cruise Control & Speed Limiter in one stalk
And ASL stands for The Adjustable Speed Limit. Hello to everyone, this is my first thread I ever made, anywhere.
Big "thank you" to CTScott, who inspired me to make things his way. I own Yaris 2015 1.33-VVTi Active 1NR-FE that comes in package without Cruise Control and ASL. And that's what I thought... After thoroughly examination of Cruise Control threads here on YarisWorld, I had to test is Cruise Control System really there (clutch Start and End position switch factory installed). So after short connecting pins 3 & 4 (z7 connector under the steering wheel airbag) I got the Cruise Control light on. Z7.png 15.jpg Green light to obtain stalk I found almost nothing about this feature on the internet (for Yaris and on forums). It's command button is located on steering wheel's right side.02.jpg First I had to make sure that wire for ASL exist. In diagram, it is light green wire on position 11 of F5 connector. Since this is a manual transmission, shift pad installation is not present. 03.png And again, using CTScott's method of examining the F5 connector hidden under the steering wheel cover, there it was, light green wire on pos. 11. F5.png 04.jpg After short connecting pins 11(ASL) and 2(ECC) I got the ASL light on (with ignition switched to ON) 14.jpg Looking at the diagram, and later by examining pins, position 11 goes to position 4 of the z-2 connector in steering wheel, but of course, no wiring ![]() z 2 pm.png 06.jpg I was really hoping that there was a hidden button on the PCB, but of course there is not... To make this work, you need complete set of wiring and steering commands that is sold as a one part and price... 07.jpg 08.jpg 09.jpg Position is present but no wire. They could supply those LED's too, Nissan Micra has them... Btw this yellow ECC connects to the pin5(z2) that connects to the empty pin 12(f5)??? 10.jpg Considering the investment and to find it second hand (holy Grail is more common to find) I was saying goodbye to ASL .And then I thought, how to implement ASL into the CC stalk? What I intend to do is to install a small push button in front of the stalk, (bit bigger and black) 13.jpg pull the wire and then use pins 1 and 4 of z7 connector. (Pin 2(z7) is the horn as well as the blue wire pin 1(z2)) 12.jpg To make this work, I will have to move the light green ASL wire from the pin 11 to the empty pin 7 of f5 connector. 11.jpg Pin 7(f5) connects to pin 1(z7) and pin 4(z7) is already ECC. Last edited by Gagi; 10-21-2016 at 01:27 AM. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Retro fit Cruise Control into a 2009 Yaris hatchback | 42ezra | Performance Modifications | 1 | 05-03-2009 12:04 AM |
