Old 06-18-2007, 11:37 PM   #1
Jerkratt
Jerkratt's Avatar
timeing belt?
do we have one and if so how can u check ur timeing and what would i need
"It hurts more when its wet"
Old 06-19-2007, 01:19 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
No, we don't have a timing belt; we have a timing chain that is internal and requires no scheduled service.
PetersRedYaris is offline   Reply With Quote
Old 06-19-2007, 03:14 AM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
So no need to service it, ever?! Makes me even happier investing in a Yaris~
Old 06-19-2007, 08:37 AM   #4
Disturb3dMind3d
Drives: 07 Yaris LB
Supposedly you have to go in for some kinda service at 100K miles.
Disturb3dMind3d is offline   Reply With Quote
Old 06-19-2007, 09:56 AM   #5
fearturtle44
Drives: S Flint Mica
Chain is much better than a belt as the belt has to be replaced every 60,000 miles whereas a chain only needs an inspection/possible replacement after 100,000.
Kevin
fearturtle44 is offline   Reply With Quote
Old 06-19-2007, 11:44 AM   #6
Jerkratt
Jerkratt's Avatar
yes thats what i thought but for some reason it slipped my mind about the timeing chain.... cant that get off timeing like a belt if u do stuff like the crank pulley for instance
Old 06-20-2007, 03:11 AM   #7
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Thats a relief. I wont be reaching 100k any time soon, unless I decide not to live in a dorm and end up commuting to UCLA everyday from Nor Cal
Old 06-20-2007, 04:09 AM   #8
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
its a timing chain, which never really goes out of spec, the 100k mile service is normally for the guides and sometimes the tensioners which will usually go bad around 150k, when you will start hearing a metal scraping noise. You normally just get a timing chain kit which includes new everything.
turboyaris is offline   Reply With Quote
Old 06-20-2007, 10:00 AM   #9
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Timing chains are usually unheard of on an "economy" car like ours. They cost more and also produce a little more noise than a belt. Another reason the Yaris kicks ass! I think the Versa and Fit both have chains as well.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 06-20-2007, 11:54 PM   #10
clayky
Drives: '07 Yaris S Sedan
Honda is notorious for their use of belts, all Nissans use chains.
clayky is offline   Reply With Quote
Old 06-21-2007, 12:07 AM   #11
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
i'd take a noisy chain over a timing belt ANY DAY of the week!
tekmoe is offline   Reply With Quote
Old 06-21-2007, 12:46 AM   #12
PetersRedYaris
Originally Posted by clayky View Post
...all Nissans use chains.
You mean all NEW Nissans use chains. I had a Pathfinder with a $700 timing belt.
Absofreakinlutley!!!
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 11:37 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 09:37 AM
Does the Yaris' engine have a timing chain or belt? grampi General Yaris / Vitz Discussion 8 05-12-2007 04:59 AM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 03:20 AM
Belt Kitt DIY / Maintenance / Service 3 12-07-2006 12:37 AM
