Old 03-25-2018, 05:32 PM   #1
Skones
Drives: Yaris
Question Speedometer and odometer priem
Hi. I have a 2002 Yaris purchased and used in the Uk. For 6 months the speedometer has worked intermittently until the last month when it has stopped working completely. It has a digital instrumentation panel and the reading appears but is consistently zero. The Odometer is also not registering the miles travelled and is stuck on the last number it reached before the speedometer stopped. I have checked the connectors at the back of the panel and the are all fitted securely. A garage tells me that I am looking at £210 ish ($250) which is not really worth it given the age of the car. However. I am not sure they know what the problem is. My guess is that it is the speed sensor. I am a novice car maintainer. Where is the sensor located on a 2002 Yaris. I read it might be in the gear box in which case it is too much to tackle but I also read that it may also be situated reasonably accessibly on the transmission and removable quick easily. Has anyone got any advice on if and how I should tackle this problem?
Skones is offline   Reply With Quote
Tags
odometer, sensor, speedometer
Speedometer, brake light, odometer all gone weird boneyking DIY / Maintenance / Service 0 07-01-2014 02:30 AM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 10:00 PM
Speedometer david.gartee1 General Yaris / Vitz Discussion 5 07-15-2011 03:32 AM
Odometer calibration Tfade25 UK 2 07-25-2009 07:32 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 11:38 AM
