Old 05-29-2018, 03:14 AM   #1
komichal
Brake fluid ATE DOT 4 SL.6
Hi folks,
can I use ATE DOT 4 SL.6 for my brake system or is it better to use ATE DOT 4 200 ?
The SL.6 should be suitable for modern systems such as ESR, ASR... my Yaris does not have it, it only has ABS. I suppose the SL.6 would mean no harm (it is surprisingly even cheaper then DOT 4 200 which is not suitable for ESR, ASR).
I am actually thinking whether the low-viscosity SL.6 can lead to leaks in my 10 year old brake system? Something like with the engine - if you have old engine that consumes a bit of oil you can increase the oil viscosity a bit and it helps.
The generic advice "put in there whatever you are having now" does not help as I have no clue what is in there. I only know that there is some "ESSO" there but no more specs available.
I suppose that "any new DOT4 will do a better job than current old one" but as the brakes are the most critical system I would like to make sure they are treated properly.
Thank you.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Question About Brake Fluid Condition dave mac DIY / Maintenance / Service 13 12-23-2017 12:46 PM
Brake Fluid reservoir hose, is it suppose to be like this ? Goldenyaris DIY / Maintenance / Service 0 12-15-2014 08:31 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 04:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
