Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 12-20-2018, 11:26 PM   #1
Kmartboy808
Drives: 2008 yaris hb
2008 yaris starts then dies out in 10-15 seconds
I need help guys. My 2008 yaris hatchback giving me problem. I've been trying to figure it out for about 2 months now and I'm trying to work on it the cheapest way possible. When I start my yaris, it starts then it dies out for about 10-15 seconds. I tried putting different MAP Sensor but it didn't help at all. I end up replacing the 3 yrs old battery because of keep on starting it.
Sent from my SM-N960U using Tapatalk
Kmartboy808 is offline   Reply With Quote
Old 12-21-2018, 02:41 PM   #2
Jeanseb29
Drives: Toyota Yaris RS 2011 (HB)
Maybe something blocking your exhaust system?
Jeanseb29 is offline   Reply With Quote
Old 12-21-2018, 03:35 PM   #3
tmontague
tmontague's Avatar
Why didn't you just charge the battery instead of buying a new one?
I'm not clear in your issue, it starts forb10-15 seconds and then dies. Is this every time and if so does this mean the car will never run or does it start again then runs fine?
Old 12-21-2018, 04:33 PM   #4
Leegamer
Leegamer's Avatar
Could be a fuel pressure issue. Does it keep running if you get on the gas a bit?
I'm a hermit named Lee
Old 12-24-2018, 04:14 AM   #5
Kmartboy808
My friend let me borrow his scanner. It came out p0113 intake air temperature sensor input high. I can get it started but only 10-15 seconds even though I press the gas pedal. It sounds like it's choking.
2008 Yaris Misfiring Code Issues TubbusMaximus DIY / Maintenance / Service 11 04-06-2020 11:23 PM
P0705: Yaris 2008 stuck in first gear in D position eepp DIY / Maintenance / Service 3 01-22-2018 12:24 PM
5spd 2008 Toyota Yaris trade for auto yaris tengys Cars for Sale by private party 8 03-07-2016 06:04 PM
