![]() Drives: 2011 Toyota Yaris Join Date: Jun 2016
A/C - water leaking through fan onto carpet...
I have a lot of water leaking onto the carpet on the passenger side, and its coming right through the fan motor. When I go around corners to the left, the accumulated water can be heard splashing up into the fan blades - is there a drain hose somewhere that I can access (if that is indeed the problem), and blow whatever is plugging it up out? Sure would hate to have to take off the entire dashboard to get at the fan housing etc.... Suggestions-fixes?.... thanks.
#2 | |
From one of the many other similar threads
Hey, it was easier than I thought! I pulled back the carpet on the side of the firewall, and found the drain hose going from the water resevoir to the where it exited through the firewall. Pulled out the hose, squeezed it several times, and a bunch of "moss" came out... after that, it started draining, so I put it back into the firewall, and it proceeded to drain out water for a solid minute! Must have been a quart of water in there... thanks for the initial inspiration to get under the dash and take a look! :)
| Yaris leaking water pump | SeattleCommuter | DIY / Maintenance / Service | 10 | 05-16-2015 10:03 PM |
| A/c fan operation. | mrpj | Third Gen Yaris General Discussion | 1 | 03-29-2015 07:57 AM |
| 2008 yaris leaking water when a/c is on-not coming from pipe | ssh4327 | DIY / Maintenance / Service | 1 | 06-19-2014 06:33 PM |
| Water leaking from A/C fan housing | Yarflana | DIY / Maintenance / Service | 2 | 10-29-2013 10:58 PM |
| A/C leaking and running cold even when turned off! | angrygenerator | DIY / Maintenance / Service | 2 | 03-31-2012 11:26 PM |
