Drives: 2008 Yaris Join Date: Sep 2018
Wipers sometimes only work when pulled
Hi, I have a 2008 Toyota Yaris and I replaced my windshield wiper motor back in April this year after the motor completely failed. Everything seemed to be ok, but recently with the rains coming, I've actually had to use the wipers more often, and I've noticed that the wipers aren't always responding to my commands. Often I actually have to either pull over and gently pull on one of the blades in order for it to work, or I have to find a bump in the road and go over it with the wiper switch turned on. If I hit the bump right, the wipers will work. I think it's an alignment problem where the motor isn't returning to its proper starting position. Any thoughts?
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Based on your description I suspect that your wiper linkage/transmission is the issue and needs to be adjusted or repaired/replaced. The wiper transmission or wiper linkage connects the wiper motor to the wiper arms and synchronizes their movement. It can jam up and sometimes just a adjustment is need, the bushings on the pivot points wearing out is the most common failure point. You'll need to take off the wiper arms, and the large plastic cowl piece under them to get a good look at the wiper linkage.
https://www.rockauto.com/en/catalog/...nsmission,8856 |
| variable intermittent wipers | thebarber | Cosmetic Modifications (Exterior/Interior) | 27 | 10-18-2022 04:26 PM |
| My Work, Your Work - Stories and Fun | SmallCarGuy | Off-topic / Other Cars / Everything else Discussions | 0 | 09-02-2007 08:43 PM |
| Making Intermittent Rear Wipers | ttufrosty | Cosmetic Modifications (Exterior/Interior) | 1 | 08-12-2007 11:57 PM |
